It is currently Tue Jul 01, 2025 12:49 am
PostPosted: Wed Jun 22, 2005 10:20 am
I am attempting to fit a 2 speed wiper motor from later model. I have conflicting wiring diagrams and also unsure which type of toggle switch to use. Any suggestions
PostPosted: Wed Jun 22, 2005 7:30 pm
MK2 S (late) with 2 speed wipers had a special toggle switch for this. It has 1 more terminal than a headlamp one. Sorry, I don't have its part #...
We have a 2 speed motor in Barney, using a headlamp switch, but the park doesn't work. Doesn't bother me, as I ran an 850, they didn't park anyhow!
Note if fitting a Clubbie motor to a Mk1 with RH park wipers- if you don't change the wheelboxes to later type (somehow), the wipers will sweep a full 180*.... :shock:
PostPosted: Thu Jun 23, 2005 11:02 pm
I put a two speed clubby wiper motor in my L/H park LUX.Used a MG lucas two speed wiper switch to match the original ( P/n BHA4786 , $67 at MG spares ) and the BLACK BOOK wiring diagrams I traced where the wires went on a clubby wiper switch and with a multi- meter compared the terminals in the new switch to connect the wires. Had to run one extra wire from the wiper motor to the the new switch.
68 Deluxe. All the Options and Mods. Bling-Bling.
