It is currently Sat Jul 19, 2025 9:45 am
PostPosted: Wed Nov 13, 2013 7:48 pm
Love my little Mini.
The other day I noticed a very small leak coming from my clutch slave - no big deal. Suuuuuure
As I start to dig in my perfectionist nature kicks in, and next thing you know my daily driver is getting a full overhaul. :oops:
Anyway, as you guys all know working under the bonnet of the mini is a bit tight at the best of times. Add some air conditioning and various plumbing, and it's really a problem. I've decided that since I didn't exactly buy a Mini for the modern creature comforts, I'm going to tear the whole system out and clean up the engine bay. But, before I dig in I just thought I'd jump in and see if anyone has undertaken this job before? Any gotchas or words of wisdom? Anything I should look out for or be weary of?
Secondly - anyone in the market for a working air conditioning unit and all the fixins?
Cheers, thanks guys!
-Brian
1998 Rover Mk VII
2001 Honda CBR 929RR (street)
2014 BMW S1000RR (track)
PostPosted: Wed Nov 13, 2013 11:47 pm
Yeah im after a full ac setup
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Thu Nov 14, 2013 9:00 am
It's not hard to remove at all, I've got it down to a fine art in my car.
A rough guide to remove the AC parts:
1. de-gas the system.
2. remove the two flex hoses to the compressor.
3. remove the receiver/drier and the pipe running along the firewall.
4.remove condenser - easier than it looks, just undo the top bracket and it'll lift up.
5. (optional) remove the fan and block the hole.
6. remove cd player and dashboard - this will give access to remove the under dash unit.
7. the hard one: remove the compressor. this may involve removing the radiator and alternator to gain access first. Once it's off you'll need a new fanbelt.
Let me know how much you want for the parts: I could use some spares.
:D
PostPosted: Thu Nov 14, 2013 2:39 pm
Harley,
You're a legend mate. I'll make you a good offer on the parts - come drink my beer this weekend and bust a knuckle or two, and you can take as much as you can carry. :D
Realistically though, this all sounds pretty straightforward and I'm happy for every stage of this right up until you started talking about the dashboard. Every time I touch an interior, clips start breaking, bits start flying and now I have to live with rattling noises for the rest of my days. Seriously, free beer at my place for anyone who can teach me how not be a retard on interiors...
Thanks guys.
-Brian
1998 Rover Mk VII
PostPosted: Mon Nov 18, 2013 10:26 pm
Remember that slight leak in the slave cylinder? Jeez I'm an idiot. :shock:
https://drive.google.com/file/d/0Bzfw-s ... sp=sharing
So anyway, I've run into a brick wall. The whole car is in pieces, and I can't for the life of me figure out how to detach the pipes that go through the firewall and into the cabin. I see the bracket on the firewall, but even if I remove it, wont the pipes just travel through it, or is it actually a connection point that dis-assembles?
Of course those two nuts are frozen on, and the stud is turning right along with the nut. I can't imagine a way to get to the other side of that bracket (the interior portion), and even if I did - does it have a phillips head or allen key? I can't eyeball it, but it feels like a smooth stud that was meant to be welded?
Ugh. Any help would really be appreciated - I'm sooo close!!
-Brian
1998 Rover Mk VII
PostPosted: Tue Nov 19, 2013 8:34 pm
AHA! It's under the goo. :|
For anyone doing this in the future - there's a connection in the hose about 100mm up from the firewall bracket. You wouldn't know it because it's pancaked inside roofing tar of some sort. ;)
Success. Time to put the rest of it back together. :)
1998 Rover Mk VII
PostPosted: Wed Nov 20, 2013 1:15 pm
The good old denso tape - yep its there to minimise the chance of the fittings corroding together.
It works well, its just a pity they didn't put it on all the fittings.
PostPosted: Mon Dec 02, 2013 10:19 pm
will the a/c system fit a 60s mini? lol
PostPosted: Tue Dec 03, 2013 9:57 am
Yep. 8)
