tie rods?? https://www.ausmini.com/forums/viewtopic.php?f=5&t=8363 |
Page 1 of 2 |
Author: | 13secmini [ Wed Jun 22, 2005 5:21 pm ] |
Post subject: | tie rods?? |
Hey guys and gals,, Im putting in some new cones and hi-los on the front of my mini. Im also changing all the bush's too including the tie rod ends... This leads me to a question, are the tie rods suppose to be bent? is this how they adjust the toe in without having adjustable tie rods???? My drivers side one is very bent and the other is alittle. Now i knew these where like this before i did the conversion but just thought they are ment to be like that. thanks, brad. |
Author: | 68matic [ Wed Jun 22, 2005 6:23 pm ] |
hey brad mine are bent and people in the know say theyre not sposed to be at all |
Author: | GT1360 [ Wed Jun 22, 2005 6:25 pm ] |
i am sure mine are straight.. I got a feeling people bend them for adjustment... i am sure Drmini will help on this. ![]() |
Author: | miniVan [ Wed Jun 22, 2005 6:31 pm ] |
mine are straight, i adjusted them by putting spacer washers before/between the bushes and the subframe |
Author: | TheMiniMan [ Wed Jun 22, 2005 6:59 pm ] |
"""Tie Rods""" are the things comming out from the steering rack, where you screw on the "tie rod ends" """Tie Bars""" (strut bars or radius rods as others like to call them) are the arms joining the lower control arm to the front of the subframe. both tie rods & tie bars are meant to be straight,,,not bent. |
Author: | miniVan [ Wed Jun 22, 2005 7:07 pm ] |
wasnt paying attention, got caught up in the ignorance, but yes i meant radius arms.. but mini call them tie bars right? but my tie rods are also straight |
Author: | 13secmini [ Wed Jun 22, 2005 7:09 pm ] |
thanks matt, yeh tie bars is what i ment ![]() |
Author: | drmini in aust [ Wed Jun 22, 2005 7:34 pm ] |
13secmini wrote: thanks matt, yeh tie bars is what i ment
![]() Brad, if I had your power I'd be looking for adjustable ones, thicker & stronger. ![]() $100.18/pr at Karcraft. Cheap.... ![]() |
Author: | Besser [ Wed Jun 22, 2005 8:43 pm ] |
Post subject: | Tie Bars |
Consider the reason yours are bent! Does it have anything to do with the body/subframe? Getting straight ones may result in a worse geometry. Also I agree with DR if you can get the adjustable ones you are on the "track" to good handling. I converted my standard ones to adjustable and with the adjustable lower arms set up a really sweet handling package. |
Author: | drmini in aust [ Wed Jun 22, 2005 8:50 pm ] |
These things get bent usually because people jack under them, or tie onto them for towing or tiedown. You can straighten them properly in a vice, if you take them off. But they are bloody flimsy for a car with big HP. Might as well get thicker ones, and adjustable too. Good value for 100 bux! |
Author: | minstar [ Thu Jun 23, 2005 10:58 am ] |
Brad, I bought these along time ago but they are basically race spec, and fully adjustable. Weren't that much either considering. I have run over several pedestrians and they haven't come close to bending! ![]() ![]() ![]() |
Author: | MiniGT [ Thu Jun 23, 2005 1:34 pm ] |
hey 13secmini, Your mini is registered in NSW isn't it? Would i be able to PM you about some of the particulars in getting it on the road in NSW? ![]() thanx, Pierre |
Author: | 13secmini [ Thu Jun 23, 2005 1:42 pm ] |
yeh no problem, |
Author: | gafmo [ Thu Jun 23, 2005 5:36 pm ] |
Same as the one's I puchased from Karcraft ![]() |
Author: | 13secmini [ Thu Jun 23, 2005 7:03 pm ] |
they look great matt,, will be putting them on the next to do list ![]() |
