Clubman Half Roll Cage https://www.ausmini.com/forums/viewtopic.php?f=5&t=83838 |
Author: | WasabiPimpNinja [ Fri Dec 13, 2013 1:43 pm ] |
Post subject: | Re: Clubman Half Roll Cage |
Hey Micool, I don't have a half cage but have been looking into it. I know in WA a 4 Point Roll Cage is legal in any car, although an application for modification needs to be made to the Department of Transport and approved prior to modification. The car then has to go over the pits to check the modification. I don't think it's required but the few people I know who have put a 4 point in their car (Sil80, RX7, S15) had the rear seats and rear seatbelts removed and had the car changed to a 2 seater. I've been quoted here in Perth around $1200 for a custom weld in CAMS 4 point cage with harness mounts. I think Bond Roll Bars do a half cage (4 point) and also a full cage (6 point? with removable intrusion bars). It was awhile since I spoke to them but I'd say they still do it. Hope this helps mate. Cheers, Keels. |
Author: | simon k [ Sun Dec 15, 2013 10:48 am ] |
WasabiPimpNinja wrote: I think Bond Roll Bars do a half cage (4 point) and also a full cage (6 point? with removable intrusion bars). It was awhile since I spoke to them but I'd say they still do it. they still do them |
Author: | micool [ Tue Dec 17, 2013 3:11 pm ] |
found a company in Wollongong called pro fab that can make a custom one. |
Author: | Clutch-monkey [ Mon Jan 06, 2014 1:33 pm ] |
micool wrote: Hey Guys just wanted to know if anyone is running a street Car with a half roll cage. yep, not in the mini though (cramped enough ![]() you'll find on older cars/pre ADR stuff, not only do we have much more latitude in the things we do to them, that you won't get pulled up for it (prob for that reason...), police tend to leave classics alone. welded in halfcage (two seater so no problem) ![]() bolted in halfcage (originally 4 seater so bolt in only) ![]() |
Author: | MINImal effort [ Tue Jan 07, 2014 5:48 pm ] |
http://www.rms.nsw.gov.au/registration/downloads/vsccs_faqs.pdf Quote: Can roll cages be used in vehicles as long as they are designed and constructed properly? Roll cages can be used in vehicles provided the installation meets the applicable vehicle standards. Installing a roll cage has the potential to affect one or more Australian Design Rules (ADRs), in which case certification will be required. The relevant standard is the requirement in Clause 21 of Schedule 2 of the Regulation that everything in a vehicle’s construction and operation must not pose a danger to any person. Four-point roll cages can still meet this requirement, however six-point roll cages cannot because the configuration of a six-point roll cage creates a rigid item directly in the head-strike area and obstructs the driver’s vision through the windscreen and adjacent side windows. A six-point roll cage may be installed in a vehicle if the front part is removed when the vehicle is used on a road or road-related area. Guidance on the fitting of roll cages can be found in Section LK of VSB No.14. http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/NCOP7_Section_LK_Seating_and_Occupant_Protection_1Jan2011_v2.pdf |
Author: | Sydney Minis [ Wed Jan 08, 2014 8:38 pm ] |
I have a 6 point cage in one of my street cars however it was engineered 10 years ago when laws were different. I still had to have it engineered as it is now registered as 2 seater because of the two rear arms that go to the parcel tray render the back seat useless. It's a bolt in cage with a diagonal brace behind the front seats. |
Author: | micool [ Fri Jan 10, 2014 11:08 am ] |
Don't wont to go as far as 6 point still want to have the rear seats in it. there is not many pics on the net. |
Author: | davem [ Fri Jan 10, 2014 12:36 pm ] |
I've got a half cage in a round nose with access still for rear occupants, l don't know the manufacturer though |
Author: | micool [ Fri Jan 10, 2014 12:58 pm ] |
are you able to post some pics for me mate ? |
Author: | davem [ Fri Jan 10, 2014 2:42 pm ] |
Not really a 4 point sorry but anyway ![]() |
Author: | Bennjamin [ Sun Jan 19, 2014 7:50 pm ] |
davem wrote: Not really a 4 point sorry but anyway ![]() alittle more info on your setup - keen on something exactly like this ![]() Custom made or kit ? Where from / cost ? |
Author: | davem [ Sun Jan 19, 2014 8:25 pm ] |
Sorry mate came with the car, no branding on it |
