Gauge swap https://www.ausmini.com/forums/viewtopic.php?f=5&t=8395 |
Author: | Marvin [ Thu Jun 23, 2005 4:55 pm ] |
Post subject: | Gauge swap |
Was wondering if I had a clubman 2 gauge/pod and a clubman 3 gauge/pod, would it be possible to remove the fuel/temp gauge from the 2 gauge and replace it with the tacho from the 3 gauge so that the 2 gauge had a speedo/tacho combination instead of the speedo/fuel combination? Does that sound right? |
Author: | drmini in aust [ Thu Jun 23, 2005 9:48 pm ] |
Short answer = no. The `wiring' to the 2 instruments you have is via a printed circuit board (PCB) at the back. Cars with a 3 clock set including tacho have a different (wider) one that does all 3. |
Author: | Marvin [ Thu Jun 23, 2005 10:07 pm ] |
Yep I know about the PCB, I was just wondering if I could put a hole here, a cut there in the right places missing the essentials of the PCB |
Author: | min13k [ Thu Jun 23, 2005 10:09 pm ] |
what will you do for a fuel gauge makka |
Author: | Marvin [ Thu Jun 23, 2005 10:13 pm ] |
a couple of small ones for temp and fuel |
