Clubman Tacho's
https://www.ausmini.com/forums/viewtopic.php?f=5&t=84789
Author:  Ian49 [ Mon Mar 03, 2014 3:54 pm ]
Post subject:  Clubman Tacho's
I have to replace the tacho in my clubman. The original had connections for a white wire running from the ignition switch to the tacho, and then from the tacho to the coil. Also has a wire going to a screw in the printed circuit behind the speedo and an earth connection on the printed circuit. The (second hand) replacement I bought has the wire going to a screw in the printed circuit behind the speedo and the earth connection on the printed circuit but only has 1 connection on back - can anybody tell me how this hook's up?
Author:  wazzie1985 [ Tue Mar 04, 2014 9:17 pm ]
Post subject:  Re: Clubman Tacho's
Hey mate. I have the same problem your talking about with my 3 gauge cluster. The 1st one I picked up has one wire from the coil, another from rear of speedo to tacko and wire from resister thing on bottom to tacko. The next one I picked up has another wire heading to tacko (white wire) if I can work out how to post a photo ill show u. We both need opposite tackos lol.
Author:  wazzie1985 [ Tue Mar 04, 2014 9:33 pm ]
Author:  Ian49 [ Wed Mar 05, 2014 10:53 am ]
Yeh, My old one is the same as the lower one in your pic. The heavy white wire comes from the Ignition switch through the tacho and then on to the coil. The one I bought only has the one terminal (like the upper one in your pic) so I assume the feed goes from Ignition switch to the coil and then a wire from the coil back to Tacho but I was looking for confirmation of that.
Author:  wazzie1985 [ Wed Mar 05, 2014 2:00 pm ]
Yeah the one u have recently got. The main bigger connector goes to coil and the ignition goes to coil I guess so that white wire u dont need. And the other connector comes from the speedo or resistor thingy. Hope this helps. Either someone else can explain a little better for u to maybe.
Author:  Ian49 [ Wed Mar 05, 2014 8:14 pm ]
Thanks Wazzie, that helps.
Author:  wazzie1985 [ Tue Apr 01, 2014 9:51 pm ]
that's ok Ian. hope it gave u some help. and anytime :) its the only
way to find out and see a problem and try solve it and help others out.
