Which 1275 to modify???
https://www.ausmini.com/forums/viewtopic.php?f=5&t=86417
Page 1 of 3
Author:  Scoop [ Sat Jul 12, 2014 5:13 pm ]
Post subject:  Which 1275 to modify???
Hi guys, I have just picked up another moke for parts (collecting next weekend). So I will have 2 Californian mokes, both 1275 models, one is late 78 and the other is late 79. I think there is a difference between the engines, the earlier one is a thin flange block and the later one has a thick flange block.
I will keep one of the mokes original but will part the other one. To much rust to recover.
Which engine would be the better one to build a strong modified grunt box? Stroker 7 port or something.
Author:  drmini in aust [ Sat Jul 12, 2014 6:34 pm ]
Post subject:  Re: Which 1275 to modify???
Either 1275 block will be fine.
Even a thin flange 1275 block is more rigid than a thick flange 1275S one.
Author:  Bubbacluby [ Sat Jul 12, 2014 6:36 pm ]
Wouldn't you just keep the correct motor with the car your keeping original?
Author:  Scoop [ Sat Jul 12, 2014 6:42 pm ]
That is the preferred way I want to go.
Author:  Morris 1100 [ Sat Jul 12, 2014 6:55 pm ]
Why would a late Californian have a thin flange block anyway?
Author:  drjbeam [ Sat Jul 12, 2014 10:21 pm ]
78-79 both sound like late models to me wernt they started in 66 to be made
Author:  Scoop [ Sun Jul 13, 2014 8:37 am ]
Should they both be thick flange? Does anyone one now what engine prefix should be in it?
Author:  Scoop [ Sun Jul 13, 2014 8:40 am ]
They are both late mokes but are before the galv body. Both have fuel fillers on the top of the side box.
Author:  drmini in aust [ Sun Jul 13, 2014 8:48 am ]
All 1275 blocks from ~1969?-1970 on were thick flange. No idea of the engine numbers for a late 70s Moke though.
I believe the very last (~1981?) gal Mokes had a 1275 A+ motor, we put one in Barney the pretend S.
[edit] Barney's A+ motor was a 12H706AAZ one
Author:  mini0998 [ Sun Jul 13, 2014 9:06 am ]
I have a moke thick flange 1275 block in my 63 mini. It's engine number is 1204 ****. Not sure what year it is though.
Author:  Morris 1100 [ Sun Jul 13, 2014 10:44 am ]
The 1204 block is out of the Export Moke from 72-73.
The late Mokes from 78 to 82 with the 1275 motor have a 12H902 motor and maybe a 12H905 on the last ones. There might be another couple of prefixes as well.
A thin flange block is going to be a 12YD/Ta/H from 67/68.
Author:  winabbey [ Sun Jul 13, 2014 12:39 pm ]
PM John Sneddon on here. He has a full list of Mini and Moke body and engine number data.
Author:  drmini in aust [ Sun Jul 13, 2014 12:48 pm ]
From the Moke forum-
1275 engines in 1981 Mokes should have a 12H706AAZ engine prefix.
http://www.moke.com.au/Forum/index.php?topic=6150.0
Author:  Morris 1100 [ Sun Jul 13, 2014 12:55 pm ]
Why would the prefix numbers suddenly go backwards? Especially backwards to an existing Mini 1275GT prefix? :mrgreen:
Author:  drmini in aust [ Sun Jul 13, 2014 1:18 pm ]
No idea, but the 706AAZ is an A+ block, the others are not.
Don't these UK sourced numbers just indicate the odds and ends fitted? eg alternator, emissions gear or not, etc?
[edit]
Seems common to late Mokes-
http://www.moke.com.au/australian-moke- ... ?start=270
Page 1 of 3 All times are UTC + 10 hours
