Specialist Components direct injection
https://www.ausmini.com/forums/viewtopic.php?f=5&t=88315
Author:  JC [ Fri Jan 16, 2015 9:15 am ]
Post subject:  Specialist Components direct injection
I don't even own a mini anymore and I would tempted to buy this...
https://www.facebook.com/441656335284/photos/a.10155073239400285.1073741853.441656335284/10155077687515285/?type=3&theater
If the image does not work, add Specialist Components on Facebook. <mod edit - changed it to url>
Wow.
Author:  1018cc [ Fri Jan 16, 2015 9:58 am ]
Post subject:  Re: Specialist Components direct injection
:shock: That looks amazing. I want one.
Author:  JC [ Fri Jan 16, 2015 10:42 am ]
Guaranteed not to let water into the bores.
Edit: indicative pricing.... £3000
Author:  Mr Orange [ Fri Jan 16, 2015 5:33 pm ]
Have been following this with interest, it's technically pretty incredible.
Though I'll stick with the time honoured method of a weber throwing some fuel and air in the general direction of the ports. Seems more fitting.
Author:  Mick [ Fri Jan 16, 2015 5:47 pm ]
JC wrote:
Yikes!
Author:  simon k [ Fri Jan 16, 2015 7:47 pm ]
I was dreaming about doing the same thing a while ago - seeing it in the flesh is pretty good
Author:  drmini in aust [ Fri Jan 16, 2015 7:58 pm ]
So how is this going to help `charge robbing' on a 5 port head? You will just have air charge robbing, instead of air/fuel mixture robbing.
2 cylinders will still get better volumetric efficiency (cylinder filling) than the other two do. Yes? No? Maybe?
IMO they should have done it with a 7 or 8 port head.
Author:  simon k [ Fri Jan 16, 2015 8:54 pm ]
they're talking about the charge robbing problem you get when trying to do multipoint sequential injection
Author:  JC [ Fri Jan 16, 2015 9:01 pm ]
Force feed it
Author:  Morris 1100 [ Fri Jan 16, 2015 9:07 pm ]
Even with the charge robbing that will happen with siamesed port you could now go to extremes and build an engine that takes that into account since you don't have to worry about what the fuel is doing.
I see the possibility of using different compression ratios for different cylinders.
Author:  KLAS [ Mon Jan 19, 2015 11:38 pm ]
maybe i should have used electronics for my DI A-series engine instead of a mechanical diesel pump.
but Mitsubishi was the only one with such a system back then and parts were expensive
Author:  simon k [ Tue Jan 20, 2015 11:35 am ]
oooh, interesting - details?
Author:  simon k [ Tue Jan 20, 2015 11:45 am ]
very good video from Bosch about direct injection... https://www.youtube.com/watch?v=LjJSbHxIvnM
I'm not keen on how they make out that they invented port scavenging though!
Author:  timmy201 [ Tue Jan 20, 2015 1:00 pm ]
I'm always glad to see people still putting time and effort into the old A-series engine!
Author:  KLAS [ Tue Jan 20, 2015 7:36 pm ]
very basic set up. i read some articles about direct injected plane engines and the story about first DI car engines and came up with this quite stupit idea.
belt driven injection pump from a 1.7l Opel diesel engine, cheap as hell over here, fitted to a 998ccm engine. some, modified for lower pressure, DI diesel injectors.
had some problems. hard to start when hot, if running it won't run very well, had some leakage problems.
sure if you invenst more time and money it could work much better. maybe using a non-diesel pump, purpose designed injectors, and so on.
i lost interest as cost start to increase to iron out the faults. and as the price for "regular" EFI dropped i went this route.
