It is currently Sat Jul 05, 2025 11:42 am
 Post subject: megajolt problems
PostPosted: Sun Mar 01, 2015 7:08 pm
having problems with megajolt instalations have 2 on my mini [2engines] they were both running fairly well until friday when one started to play up,misfiring etc like timing was out,have improved it but still not right,is there anybody who can offer advice please? also some one who knows DCOE webers
16v, twin cam, 'a'series, cooper S replica,3x dcoe webers,Around 200 HP and heaps of torque
 Post subject: Re: megajolt problems
PostPosted: Sun Mar 01, 2015 8:26 pm
loose wiring? VR sensor bracket loose? they really should be the ultimate in set and forget. The only time I had trouble with mine was from wiring
unless it's not the sparks, and is actually fuel. Assuming they're both using the same fuel tank, are they both getting fuel? IE are the float bowls full on both?
PostPosted: Mon Mar 02, 2015 6:24 am
Have you plugged in the laptop? What is the MJ reading? That will let you diagnose if its the MJ. Only trouble I have had is the crapy bolt on trigger wheel falling apart after lots of 8000 rpm work......fitted a KAD fluid balancer problem gone.
A proper mini redlines at 13 500 rpm ;)
PostPosted: Mon Mar 02, 2015 7:34 am
Give Ash some flowers Nick .
My money is on the wiring into the VR plug is dodgy.
PostPosted: Tue Mar 03, 2015 7:01 pm
thanks for replies.the major problem was [still is]vr sensor & wiring,hunting around for another vr and plug ,not having a lot of luck with with this ?????.plenty of fuel,in fact carbs dribble fuel seems to be a weber trait, still looking for a good weber man for tune up,
PostPosted: Tue Mar 03, 2015 8:15 pm
we run a ford falcon 6 cyl crank sensor .. if that helps and yes i'll get back to your pm shortly Snurk
PostPosted: Wed Mar 04, 2015 6:57 am
Plug: 170992920528 (ebay)
Falcon VR sensor: 151094347211 (ebay)
I run a EF falcon VR sensor and one of those plugs off of eBay. I have some issues with the wiring on my car so I actually soldered on thin tie wire rather than actual vehicle wiring to the plug. I was finding vehicle vibrations were causing the wiring just at the connectors in the plug to frey and break. Good luck but definitely stick with it.
PostPosted: Fri Mar 06, 2015 6:29 pm
new vr and plug,also coil pack was misfiring on plug 1.replaced it and seems ok now,still looking for good tuning man for my webers [in melbourne] thanks for your help.
