It is currently Fri Jul 18, 2025 11:06 am
PostPosted: Thu Mar 12, 2015 3:15 pm
Seeking any second opinions again please.
Have had the block drilled and tapped to take 5/16 bolts for block to g/box.
Should I make the holes in the 'box 5/16" or 8mm?
5/16" = 0.313" = 0.79375mm
So a little amount of movement at 8mm or virtually none at 5/16"
Does it matter??
PostPosted: Thu Mar 12, 2015 4:04 pm
Mine were done to 5/16, dont know if it matters to be honest.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Thu Mar 12, 2015 5:27 pm
I cannot see how it can matter unless the bolt holes are not square and the bolts are tight. You will find that your 5/16 bolts will all ways be undersize they always are.
Do a dummy assembly of box to block if you are concerned
PostPosted: Thu Mar 12, 2015 5:45 pm
Original bolt holes were at least 1/64" bigger than the 1/4" bolts.
I would drill them 8.5mm for 5/16" bolts.
My 2c..
This folklore of putting 5/16" bolts in to replace the 1/4" ones arose back when all the blocks were thin flange. I reckon it's a waste of time doing it with thick flange blocks, particularly for street use.
A 1380 thin flanged (1100S block) stroker I built a while back (with stock 1/4" bolts) still has NO leaks there.
Gasket sealants have improved in the last 30 years.
Don't believe everything you read in Vizard's book. :wink:
[edit] My car's Mk2S box was drilled out when I got it (had a thin flange S motor on it with 5/16" bolts). It now has a 1360 (1300auto block) on it, but with 1/4" bolts in. It doesn't leak there, either. 8)
PostPosted: Thu Mar 12, 2015 5:56 pm
It shouldn't really matter if there is a bit of play there because you should have 2 dowels to locate the gearbox and block.
PostPosted: Thu Mar 12, 2015 6:28 pm
If you drilled it 5/16 the finished hole will be bigger than 8mm anyway.
PostPosted: Fri Mar 13, 2015 5:20 am
Use a decent sealant. I use loctite 518. Its pricey yes at $50 a tube but works brilliantly. I use it on all oil joints when I build engines. Never had a leak yet..
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Fri Mar 13, 2015 8:19 am
Thanks for all the details, much appreciated. Taken it all onboard 8)
Will start with a 5/16 bit and go from there.
