??? Assuming you want it to stay in the 3-4 plane. What rodchange Mini got a bias spring?
If you want to stop it jumping the reverse gate on fast 2-3 shifts, just fit a stronger reverse detent spring. I have a `red' die spring in mine for this purpose. It is under the gearbox hex plug behind the oil filter. If you have a reverse light switch there, you will need to make a thinner actuating plunger rod.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
