It is currently Wed Aug 13, 2025 8:55 am
PostPosted: Thu Oct 08, 2015 10:56 pm
Hi everyone I am currently own a morris mini van and want to know which exhaust system, I was looking at something like the RC40 exhaust system and maniflow Cooper freeflow exhaust manifold, but am open to suggestions, also looking to buy some new shocks and some ripspeed hi-lo's I was looking at the gaz lowered shock absorbers, will I need the lowered shocks or with the standard height ones be fine just wondering
PostPosted: Fri Oct 09, 2015 11:57 am
Hi willi... Welcome !
Suggest you do some searching on the site , those topics have been covered extensively .:)
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Fri Oct 09, 2015 5:47 pm
Just a question that I have that I can't find an answer too, I saw for sale dampers that were specific to the mini van as they need to be longer at the rear, or can I use the normal ones that would come in a set?
PostPosted: Fri Oct 09, 2015 8:49 pm
Have a read of this article. http://www.minimania.com/Dampers___Fitment_data . It helped me work out if my shocks were going to fit a clubby sedan that had been lowered.
I measured the distance between my shock mounts with the car on the ground and made sure this distance was in between the shocky operating stroke. Maybe the longer length shock is because vans are supposed to be jacked up higher at the back for load carrying reasons.
