Difference Pistons early A+ & Pre A+?
https://www.ausmini.com/forums/viewtopic.php?f=5&t=91230
Author:  AlanMannClubman [ Tue Dec 08, 2015 5:35 am ]
Post subject:  Difference Pistons early A+ & Pre A+?
Hello! A friend of mine gave me a 998cc engine block which is re-bore to 040 yesterday! :D
The block is an old 998 Cooper block (Pre A+) and my question is;
This circlip/piston set intend to fit early 998 A+
http://www.minispares.com/product/Class ... 0to%20shop
Does it fit my Pre A+ Cooper stuff?
Author:  drmini in aust [ Tue Dec 08, 2015 7:19 am ]
Post subject:  Re: Difference Pistons early A+ & Pre A+?
Yes it will, as long as your Cooper has 998/1098 rods (not the old clamp bolt 850/997 ones).
Early A+ had the same rods as a 998/1098 A series. Then they changed to interference fit rod, shorter gudgeon pin with no circlips.
Personally, I would buy locally available flat top pistons, either Hypatec or Russell Engineering.
for example-
http://minisport.com.au/998-080-piston- ... op-hypatec
Author:  AlanMannClubman [ Tue Dec 08, 2015 8:10 am ]
Grrrreat! :D Thanx for quick reply!
