Yes 1.3 roller rockers are worth having, as long as you don't pay silly money. FYI, A+ rockers have the lowest lift, only S forged rockers have less.
Here's the lift figures, the head was a 12G1316 (1275 smog head) much the same as a 940 as a 12G940..
Rocker ratio = (valve lift " + .016" clearance)/.290" lobe lift
22/7/07 Checked valve lift- 12G1316 head fully assembled. RE13 cam, stock pushrod, valve clearance .016”: Lift at #1 inlet valve- S forged rockers lift 0.321”, rocker ratio= 1.16:1
A+ sintered rockers lift 0.327”, rocker ratio= 1.18:1 998 Deluxe rockers, std cast iron posts, lift 0.337”, rocker ratio= 1.22:1 998 Deluxe rockers, with A+ sintered posts (are 0.3mm shorter than CI) lift 0.339” , rocker ratio= 1.22:1
* 998 Deluxe rockers, cast posts lowered 0.6mm, offset bushed 1.0mm, lift 0.359”, rocker ratio= 1.29:1
* 998 Deluxe rockers, cast posts lowered 0.6mm, offset bushed 1.1mm, lift 0.365”, rocker ratio= 1.31:1
Toyota Corolla rockers, late `sintered rocker’ type posts, shaft offset 3.9mm back, lift 0.402”, rocker ratio= 1.44:1
Noter the offset bushes in * above were mine, bored from solid after pressing in, the offset ones you buy have less offset so less ratio.
_________________ DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
