Question re 22G1921- 4 Synchro Flywheel Housing https://www.ausmini.com/forums/viewtopic.php?f=5&t=91550 |
Author: | drmini in aust [ Fri Jan 15, 2016 7:47 pm ] |
Post subject: | Re: Question re 22G1921- 4 Synchro Flywheel Housing |
The vented one would be off a non-S 1275, probably. You can cover that hole up if you want, I use a cover plate off a Mini steering rack. Slot the screw holes a little and it fits good. |
Author: | Mark Gosling [ Fri Jan 15, 2016 10:40 pm ] |
I have a 77 with a 998, twin carbs and extractors, electronic 45D. The non vented housing is standard fitment, and hasn't proved to be a problem using it as a daily driver. It travels on the highway and the city without problems. The clutch is three years old and has no problems. Hope this helps. Mark. |
Author: | MiniKado [ Sat Jan 16, 2016 6:39 pm ] |
Thanks fellas, I'll conjure something up to cover that hole then if no real advantage having it there. Cheers. |
Author: | simon k [ Mon Jan 18, 2016 4:00 pm ] |
if Matt Read chimes in, he'll explain that the transfer housing needs to match the gearbox case so that the idler gear and outrigger bearings are aligned properly The best one to use is the one that came from the factory with the gearbox casing, but it's probably too late for that |
Author: | MiniKado [ Mon Jan 18, 2016 5:14 pm ] |
No, not yet. The Non Vented housing in this pic is the one from the gearbox I'm rebuilding. But did intend to use the other. Interesting. Wouldnt mind some other feedback if this is the case (case, gearbox ahh you know what i mean) |
Author: | TheMiniMan [ Tue Jan 19, 2016 9:34 pm ] |
Author: | 1071 S [ Fri Jan 22, 2016 5:12 pm ] |
Soooo they line bored the the transfer case and gearbox case???? Never heard that before.... Cheers, Ian |
Author: | drmini in aust [ Sat Jan 23, 2016 8:46 am ] |
1071 S wrote: Soooo they line bored the the transfer case and gearbox case???? Never heard that before.... Cheers, Ian Yeah I've heard of it, as a machinist, I'd like to see how they did it though! it's a blind hole, on the outside. I reckon they had jigs, and they were interchangeable when built, but not 10 years later if you tried to mix fit older and recent ones. |
Author: | sitnlo62 [ Sun Jan 31, 2016 5:40 pm ] |
1071 S wrote: Soooo they line bored the the transfer case and gearbox case???? Never heard that before.... Cheers, Ian I don't believe this to be the case either. Every Gearbox case was sold as a spare part with its matching Diff housing. It was not sold with the clutch housing bolted on as well. So one would thing that they where not machined as one unit. It really isn't that hard to drill and bore a series of holes in a housing like that and get them in exactly the right place, keeping in mind that it has 2 dowel pins to locate it correctly on the gearbox and one hole has to line up with the primary gear, which is part of the engine. Just my thoughts and logic, could be wrong ![]() Dave |
Author: | TK [ Sun Jan 31, 2016 7:35 pm ] |
"Every Gearbox case was sold as a spare part with its matching Diff housing." very good point Dave. None of my NOS gearbox cases have the clutch housing supplied but do have diff housings. |
