Starter and flywheel problem https://www.ausmini.com/forums/viewtopic.php?f=5&t=92268 |
Author: | anza [ Fri Apr 01, 2016 10:08 am ] |
Post subject: | Starter and flywheel problem |
I have a Hitachi s114-202 starter (Gemini type) with 9 teeth on my mini that i am restoring. The 107 tooth flywheel is damaged and replacing it with a 129 tooth flywheel. I think it requires an 11 tooth pinion drive for correct meshing? Is this correct ? If not can anyone tell me what I require to do to suit it. Thanks you for your help. |
Author: | drmini in aust [ Fri Apr 01, 2016 3:38 pm ] |
Post subject: | Re: Starter and flywheel problem |
If you use the later 129 tooth ring gear the Hitachi won't work. You will need a Rover pre-engaged starter. Why not fit a new 107T one and keep the Hitachi starter you have? |
