Stainless with Aluminium https://www.ausmini.com/forums/viewtopic.php?f=5&t=92460 |
Author: | Ian_B [ Sat Apr 23, 2016 12:44 am ] |
Post subject: | Stainless with Aluminium |
I am making a template for a job using old school tech drawing just to keep me occupied Ready for laser cutting.Im enjoying this. Havent done this since high school . Will stainless be OK with aluminium alloy given water or electrolyte is not present. I think so.Any ideas.Grade of stainless?? |
Author: | Ian_B [ Sat Apr 23, 2016 2:45 am ] |
Post subject: | Re: Stainless with Aluminium |
Next with some help make manifold to put Fazer bike carbs on Elder head. Bloody cast one would be good but a one off cost would be too much Webers for now |
Author: | Scoop [ Sat Apr 23, 2016 8:35 am ] |
They mix stainless with aluminum all the time on modern cars so cant see to much of an issue. As for manifolds, shouldn't be to hard to make a couple. All you need is flange plates to suit head and carbs and some slightly bent pipe between. All part of the fun! |
Author: | peterb [ Sat Apr 23, 2016 9:32 am ] |
I use stainless screws/bolts in aluminium a lot, I use a bit of never seize on them. Never had a problem. |
Author: | drmini in aust [ Sat Apr 23, 2016 6:25 pm ] |
peterb wrote: I use stainless screws/bolts in aluminium a lot, I use a bit of never seize on them. Never had a problem. All outboard motors run SS bolts in alloy. To prevent corrosion, OMC used lanolin on assembly. |
Author: | peterb [ Sat Apr 23, 2016 6:52 pm ] |
Quote: All outboard motors run SS bolts in alloy. To prevent corrosion, OMC used lanolin on assembly. And you hands will end up nice and soft too. ![]() |
Author: | Ian McNeil [ Sun Apr 24, 2016 10:47 am ] |
Hi Guys Try using Duralac jointing compound It is chromatic containing, and inhibits electrolytic decomposition between dissimilar metals. It is a single pack air setting product which will prevent anode decomposition even in a harsh marine environment such as stainless fittings on alloy masts and booms on sail boats Available most marine distributors / ships chandlers that are involved in sailing It works Cheers Ian |
Author: | Hobson [ Sun Apr 24, 2016 1:06 pm ] |
Carefull barium chromate isn't good to eat though, try not getting it on your skin in large amounts it can stick around a while. Used in aeroplanes as well as sailing boats. doesn't last forever though, well out on the water that is. |
Author: | frednutz&co [ Sun Apr 24, 2016 5:00 pm ] |
And you hands will end up nice and soft too. ![]() just be careful around sheep |
Author: | Ian_B [ Sun Apr 24, 2016 10:33 pm ] |
Thanks guys .The softer my hands the better for me lol. The middle aged eyesight thing has caused repeat efforts. I have a computer cad program but it wont resolve less than 1mm And if you make it do it the job size diminishes im not buying expensive software. |
