It is currently Mon Jul 07, 2025 3:35 pm
 Post subject: Engine temp
PostPosted: Sun Jul 10, 2016 10:29 am
What temp should the engine run at
https://vimeo.com/174051013
1968 Morris Mini Cooper S
 Post subject: Re: Engine temp
PostPosted: Sun Jul 10, 2016 1:12 pm
I usually get in the low 90's with my temp gun at idle. I check the temps on the radiator top tank, thermostat housing and heater outlet. The spots you pointed at will be warmer than the coolant temp because the heat source is just below the spark plugs.
The best time to check the temp would be during or just after a drive after the thermostat has fully opened. A mini at idle can get hotter because the lack of air flow through the radiator.
PostPosted: Sun Jul 10, 2016 2:10 pm
Sweet just went for a drive and got back top of radiator at 95
Users browsing this forum: Bing [Bot] and 5 guests
