MED Ultra light steel Flywheel https://www.ausmini.com/forums/viewtopic.php?f=5&t=93102 |
Page 1 of 3 |
Author: | fuzzy-hair-man [ Sun Jul 10, 2016 12:48 pm ] |
Post subject: | Re: MED Ultra light steel Flywheel |
Is it just me but there looks to be a fair bit more clearance between the clutch housing and the flywheel teeth in the 2nd photo than in the first, it could just be the camera angle. Not sure about the MED flywheel but don't starter rings get sweated on? ie heat it up till it expands then put the ring on the flywheel as it cools it tightens and locks. Would it be possible to compare starter gears with a genuine one or something? the starter looks centralised in the hole so maybe the starter gear isn't big enough? |
Author: | drmini in aust [ Sun Jul 10, 2016 1:42 pm ] |
Looks to me like the pinion is too small, it is not meshing properly even in the top photo. In the bottom photo it has chewed the tops off the ring gear teeth due to this same thing. IMO, the ring gear looks to be too soft if this happens. I have seen some recent ring gears get bad wear with low mileage after installation. Maybe its material or heat treatment is crap. |
Author: | Mokesta [ Sun Jul 10, 2016 5:25 pm ] |
I think that the starter has the mount holes drilled in the wrong spot. This has put the starter centre line too far away from the flywheel centre line. Poor mesh has allowed the tips of the gears to collide leading to the damage. Ring gears are always damaged more in one spot. It is where the engine tends to stop with the same piston on compression. M |
Author: | kiwiinwgtn [ Sun Jul 10, 2016 5:53 pm ] |
Pinion gear looks like the wrong profile. May I ask what filter housing are you using. Looks non mini. Kiwiinwgtn |
Author: | FNQ [ Sun Jul 10, 2016 6:30 pm ] |
i have seen a number of MED ultra lite flywheels and no problems as such, quite a good bit of kit in my opinion, but that is not to say production variables don't exist. Regarding pre -engaged vs interia- would they have differing chamfers for 10 vs 9 tooth pinion, just a possibility No idea really |
Author: | simon k [ Sun Jul 10, 2016 8:15 pm ] |
yep, sounded very yukky! I'd send the photos to MED and ask them... maybe they'll send you a new set |
Author: | dalmeny [ Sun Jul 10, 2016 9:03 pm ] |
kiwiinwgtn wrote: Pinion gear looks like the wrong profile. May I ask what filter housing are you using. Looks non mini. Kiwiinwgtn Just a Ryco Z418 on a spin on housing. |
Author: | dalmeny [ Sun Jul 10, 2016 9:05 pm ] |
Mokesta wrote: I think that the starter has the mount holes drilled in the wrong spot. This has put the starter centre line too far away from the flywheel centre line. Poor mesh has allowed the tips of the gears to collide leading to the damage. Ring gears are always damaged more in one spot. It is where the engine tends to stop with the same piston on compression. M The circular shoulder on the starter fits perfectly into the flywheel housing hole. |
Author: | dalmeny [ Sun Jul 10, 2016 9:08 pm ] |
FNQ wrote: i have seen a number of MED ultra lite flywheels and no problems as such, quite a good bit of kit in my opinion, but that is not to say production variables don't exist. Regarding pre -engaged vs interia- would they have differing chamfers for 10 vs 9 tooth pinion, just a possibility No idea really I assumed the suppler would supply bits that work together. Been in touch with MED waiting for a reply. |
Author: | dalmeny [ Sun Jul 10, 2016 9:10 pm ] |
simon k wrote: yep, sounded very yukky! I'd send the photos to MED and ask them... maybe they'll send you a new set Did that Simon, here's hoping! |
Author: | FNQ [ Mon Jul 11, 2016 7:38 am ] |
Can i count? Is that an 11 tooth pinion??? |
Author: | Boostedmini [ Mon Jul 11, 2016 1:42 pm ] |
Same, 11 Sent from my iPhone using Tapatalk |
Author: | dalmeny [ Mon Jul 11, 2016 9:13 pm ] |
Yes, it's 11 tooth, but it is a pre-engage set up. What's normal? |
Author: | KLAS [ Mon Jul 11, 2016 10:32 pm ] |
i count 9 teeth, factory starter from 1998. if needed, outside diameter is 25,4mm |
Page 1 of 3 | All times are UTC + 10 hours |
