It is currently Tue Jul 08, 2025 5:27 am
 Post subject: Flare experts congregate
PostPosted: Sat Dec 24, 2016 10:16 am
I have a set of flares that I've inherited, and I'm almost ready to fit them.
They are fibreglass, and it's reasonably clear which are the fronts and rears (fronts have a wider flare at the bumper end)
The fronts look like they will fit properly, but the rears look wrong.
The radius of the flare seems too large at the rear - see pictures.
Note that the pictures are not of the mini that they will be fitted to!
front:
rear:
Anyone had experience here before?
Thanks all
PostPosted: Sat Dec 24, 2016 10:24 am
Could they be for 13's? On a mini that has had its guards cut?
Zulu...
1967 mini Cooper S
PostPosted: Sat Dec 24, 2016 9:54 pm
your pictures are too small to see clearly, but they look like a set of flares I have in my collection... the rear sits down on the bumper seam and they sit pretty low, below the seam over the wheel arch
PostPosted: Sun Dec 25, 2016 7:46 pm
They are a bit small. here is larger:
Front
Rear
Not sure what you mean by low - if they are installed with the two ends in the right place, then the middle will be 30+mm lower than the original arch..
It's like the radius is just wrong.
Alternatively, what flares to people recommend getting that add around 40mm of width?
