It is currently Thu Jul 10, 2025 8:01 am
 Post subject: Coil
PostPosted: Wed Jun 08, 2016 4:12 pm
Hi: Previous owner was running a Bosch HEC 716 ignition coil. Unfortunately the bracket has snapped. Does anyone know if a regular cylinder shaped coil, such as a GT40 or something, will do the job? Lot easier to find brackets for the normal cylinder shaped coils. I could bodge something up for a bracket, but prefer to have things looking "right".
The engine is a metro with electronic dizzie.
1965 Austin Cooper 998 (UK built)
1963 Austin Countryman woodie
 Post subject: Re: Coil
PostPosted: Wed Jun 08, 2016 5:36 pm
i have plenty of std issue coil brakets, both the thin & the thick
Matt
0407 135 656
Murarrie Bne
PostPosted: Wed Jun 08, 2016 5:37 pm
Karcraft sells a Lucas coil to suit it. Around $49.
RTC5628/2
And a cheaper one for around $33.
Same p/no
PostPosted: Wed Jun 08, 2016 5:50 pm
Thank you
PostPosted: Wed Jun 08, 2016 7:09 pm
I'm back using a 20+ year old tatty GT40 because I've had 2 or 3 shiny modern coils fail on me.....
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Wed Jun 08, 2016 7:24 pm
Yep I also had a new one fail so the one I run now is 40+ years old and going strong
PostPosted: Wed Jun 08, 2016 8:39 pm
They don't make em like they used to. One member here had a brand new GT 40 fail out of the box last week.
PostPosted: Wed Jun 08, 2016 10:36 pm
Yeah that was me. Onto a Pertronix Flame-Thrower now which came dented out of the box courtesy of Australia Post :x
Lillee - 1969 Morris Mini K
PostPosted: Thu Jun 09, 2016 8:33 pm
My original 1970 Lucas coil still works as it did in 1970 go figure!
1970 Mk 2 Cooper S
Users browsing this forum: justminis and 86 guests
