It is currently Sat Jul 19, 2025 8:56 pm
 Post subject: DCOE Supercharger kit
PostPosted: Thu Jul 14, 2016 10:41 am
This looks like an interesting setup, apparently a newer version of the M45:
Unfortunately the image is a bit small
From the website: http://www.vmaxscart.co.uk/new-dcoe-supercharger-kit/
The new super-compact design mounts the carb closer to the charger, eliminating carb icing, and fuel run back problems. The 40/45dcoe carb gives superior power and easy jetting. The dcoe supercharger kit can be used with all bodyshells 1959-2001- no bonnet or bulkhead modifications required, left and right hand drive, with the pedal box servo assembly, kits are tailored for Small to large bore engines.
Instantaneous throttle, Super tractabillity,
And everyone loves the sound of a dcoe !
kit contents :
All new lower manifold, better flow and balance between the two ports.
40 dcoe carburettor with filter,
modified Eaton M45 '5 th generation' black rotor Supercharger, pulleys and tensioner, belt, decompression plate, gaskets and instructions for £1695 !
PostPosted: Thu Jul 14, 2016 11:41 am
Interesting.
Nick
PostPosted: Thu Jul 14, 2016 3:50 pm
looks like the M45 fitted to some Mercedes cars, with inlet elbow cut off
Rover 214 atm ....
PostPosted: Thu Jul 14, 2016 4:04 pm
where can I get one? :P
Jenk.
PostPosted: Thu Jul 14, 2016 4:33 pm
Needed to do something because the original version was a useless design with the carb where it was. I bolted the SU where that weber is and the difference was unbelievable. That's what spurred me on to injection.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Thu Jul 14, 2016 7:58 pm
What is the "best" supercharger kit on the market?
How does the hiflow system (http://www.hi-flow.com/) compare to the v-max????
PostPosted: Fri Jul 15, 2016 3:31 pm
Will this kit fit an 1098 motor or is it for 1275?
Sent from my SM-G900I using Tapatalk
PostPosted: Fri Jul 15, 2016 3:40 pm
The website says :
PostPosted: Fri Jul 15, 2016 4:30 pm
Cool
PostPosted: Thu Aug 04, 2016 4:41 pm
Couple of new photos on the site... http://www.vmaxscart.co.uk/
40mm injection twin throttle body
PostPosted: Thu Aug 04, 2016 10:36 pm
hmm a supercharger
my hilux is supercharged our new boat is supercharged now you have been given me another idea
1968 Morris Mini Cooper S
PostPosted: Thu Aug 04, 2016 11:07 pm
oldblade wrote:
hmm a supercharger
Supercharge the fireblade?
PostPosted: Sat Aug 06, 2016 7:12 am
gtogreen1969 wrote:
oldblade wrote:
hmm a supercharger
Maybe I was thinking about it for my track fireblade
