It is currently Sun Jul 06, 2025 6:33 am
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue May 31, 2005 5:20 pm
what is that round hole for? Is there any reason why it cant be filled in?
Life's a garden.... Dig It!
PostPosted: Tue May 31, 2005 5:29 pm
At the factory, the whole body can be put on a giant spit (like a huge pole going through the hole car and then spun around on it etc.
The onyl reason why it can't be filled in is laziness :lol:
Lillee - 1969 Morris Mini K
PostPosted: Tue May 31, 2005 5:34 pm
So nothing goes through the hole at all?? No cabling or anything like that?
If there is nothing goin through it then it may as well get filled while the car is getting the bodywork done...
Just did some gooogling for dynamats.. anyway came accross this bloke install it in his Bini.. Is this the stuff you were reffering to poeee?
http://public.fotki.com/PMS/panhandle_m ... page2.html
Also check this out if you want... its something called FatMat? It's installed in an old mini :D
http://members18.clubphoto.com/richard7 ... uest.phtml
yehhhh
PostPosted: Tue May 31, 2005 5:42 pm
some may want to use it later on to put it back on a spit..makes for easy work ;)
Don't the centre binnacle cables run through the hole?
PostPosted: Tue May 31, 2005 6:49 pm
dynamat is the absolute best stuff you can use, makes all the other stuff looks like crap.
very expensive.
the wiring loom goes through teh centre hole, as does the speedo cable.
PostPosted: Tue May 31, 2005 7:02 pm
I wonder how heavy that stuff is :shock:
PostPosted: Tue May 31, 2005 7:21 pm
68Delux wrote:
:lol:
I think I can cannibalise a round plate thing and pop rivet it into place
Barney has a Clubbie plate in him, but the p/o rewired the car so it fits properly, cable grommet and all... :lol:
He also lengthened all the wires onto the instruments and then screwed the binnacle onto the dash trim. So, after undoing a few screws & the early Clubby :shock: speedo cable (from inside the car), the whole binnacle etc is sitting in my lap. Beeeautiful... :wink:
PostPosted: Tue May 31, 2005 7:22 pm
Well if there is cables that go through there, best i not fill it...
PostPosted: Tue May 31, 2005 7:53 pm
yehhhh
Yep, that's the stuff. There is nothing better. All the car audio guys have tried everything, and nothing compares to dynamat.
Quite :lol:
PostPosted: Tue May 31, 2005 8:08 pm
J_A_M wrote:
7/76 model
Probably the very last of the ones with rotor dip holes. The rear seat part doesn't have a hole...only the firewall. Weird huh! :?
mines a 10/76 :P
PostPosted: Tue May 31, 2005 11:01 pm
I was going to use the silver backed foam (auto grade, often used as a heatshield on turbo cars) from Clark Rubber to line the dash/firewallwall before I give it a full dash. Im sure most of the sound is coming from behind the dash and via the hole cut for the weber. The hole houses a steel 'weberbox' but plenty of noise is getting through that section.
Which reminds me, I can fit my weber now :P
www.crazybitchracing.com
PostPosted: Wed Jun 01, 2005 9:12 am
yehhhh
I saw that stuff being mentioned on MM/MS a while back. Looks pretty good! :wink:
PostPosted: Wed Jun 01, 2005 1:19 pm
hmm my car has next to no sound proofing and has a straight through single hot dog exhaust, thats a little loud! maybe i should get some of that stuff poeee was on about........... :?
Potato
PostPosted: Wed Jun 01, 2005 4:02 pm
Because i work in the Airconditioning industry, when it is time to put the pieces of my mini back together, i might use some of the aircon units insulation... I was actually thinking about this the other week before i read this topic, I dont think the aircon stuff is real heavy either....
