It is currently Mon Jul 14, 2025 8:19 pm
PostPosted: Sun Oct 30, 2016 1:42 pm
and its fixed !!!!!
Syringed out what was not clearly the right oil in the dashpot, added some of the right stuff and she purrs like a kitten!!
Thank for the help guys
PostPosted: Sun Oct 30, 2016 3:08 pm
mooman10_0 wrote:
and its fixed !!!!!
Would not have picked that. Runs well one day and bad the next.
PostPosted: Sun Oct 30, 2016 3:13 pm
perhaps was only affecting when oil was getting warmer? When through bit by bit and that was the only thing that had any effect. Ran it for a good half an hour and no issue (so has definately fixed it :-). All I can say is minis have their own quirks!
PostPosted: Sun Oct 30, 2016 7:09 pm
Minicooper4me wrote:
I'd do one thing at a time till the fault is rectified. If you do a heap of stuff before rechecking, you won't know what the issue was. You can chase stuff all day and still not get there.
Electrical connections.
Fuel and fuel filter.
Carby needle tight in place.
Light oil in dashpot.
Sticking dashpot.
Plug leads and plugs.
Points. Correct dwell. Connections.
Condenser.
Coil. Are the connections tight and the right way around.
Dist cap cracked.
No 4 on the list. I win !
Did you do one at a time as suggested till you found the issue ?
Still don't count your chickens for a few days yet though.
PostPosted: Sun Oct 30, 2016 7:29 pm
I did do one at a time :-)
Definately solved, would have replicated by now as I have started probably 50 times this arvo to make sure :-) Would have happened every second time before :-)
PostPosted: Sun Oct 30, 2016 7:33 pm
I had your list up on my phone as I went through the check list :-)
PostPosted: Sun Oct 30, 2016 7:45 pm
Now if you can make a list up for my bloody second gear issue. PITA.
PostPosted: Sun Oct 30, 2016 7:49 pm
I wish, lol!! I figure if it only jumps out of one gear things are looking up :-)
PostPosted: Mon Oct 31, 2016 8:22 pm
especially if it's reverse. :roll:
Users browsing this forum: Bing [Bot] and 77 guests
