It is currently Sun Jul 20, 2025 11:13 am
 Post subject: Driveshafts
PostPosted: Wed Dec 28, 2016 4:59 pm
Currently restoring a 81 moke and just removed the 8.4discs and driveshafts from subframe. They are a noticeable different thickness from each side ( left to righy). I gather this is not meant to be the case? Are theyre different size ones? Both look in great nic apart from thickness.
Thanks,
Steve
 Post subject: Re: Driveshafts
PostPosted: Thu Dec 29, 2016 8:56 am
Rotors should be same thickness for even braking performance.
I would fit new ones. They are cheap now.
edit- if you are talking driveshafts, yes the RH one is thinner diameter than the left.. well my 1979 one was.
PostPosted: Thu Dec 29, 2016 11:08 am
The Mini King
There are at least two different drive shaft Diameters,
one is a lot smaller in diameter than the ones we are used to seeing.
if the thin driveshaft was fitted to Australian produced Minis
I feel sure that they would have been fitted to Mokes in the 80'S
some time back a large qty of CV & drive shaft assemblies were
imported into Australia, One side in greater Qty's than the other.
so it is possible that this may be one of them.
I was informed that the thinner one is made from a better grade metal
and is stronger than the thick one, I am not saying they are stronger
I am just repeating what I was told,
I am sure that there will be comments from people more qualified
than I, on the the comparable strengths.
I also think that when we stopped making the drive shafts in Australia,
the ones imported from the UK were a different diameter to those
made in Australia,
PostPosted: Thu Dec 29, 2016 11:25 am
Drive shafts of different length are always (if properly designed) of different diameters.. in order that the overall torsional stiffness is the same on both sides....
Cheers, Ian
PostPosted: Thu Dec 29, 2016 1:42 pm
Cheers, Ian
I hear what you are saying Ian...
So why did BL make the long RH one thinner than the short one?? :shock: Shouldn't it be the other way around?
PostPosted: Thu Dec 29, 2016 5:56 pm
I was talking driveshafts. So sounds like all should be okay refitting different thickness ones? I have already bought new rotors and rebuilt calipers/ new hoses ect
PostPosted: Thu Dec 29, 2016 8:16 pm
Yes the driveshafts are fine this is how they came on later mokes with pot joints.
