It is currently Sun Jul 20, 2025 4:55 am
PostPosted: Tue May 02, 2017 5:28 pm
I have had not much luck cleaning the inside of my fuel tanks .the petrol was in them for years I think it turns into shellac. Does not appear to be any rust in the tank. P767676
PostPosted: Tue May 02, 2017 6:16 pm
Tried soaking in white vinegar?
PostPosted: Wed May 03, 2017 8:39 am
Put some fine gravel in there, then shake, baby, shake.
PostPosted: Wed May 03, 2017 8:41 am
I used white vinegar and let it soak for a while to loosen it up then put a few handfuls of gravel in there. Seems to do a good job as far as I can see
PostPosted: Wed May 03, 2017 10:22 am
I did the one in my Traveller with Koala Kare degreaser, and a bunch of nuts threaded together on a string, with lots of shaking. That took out the small amount of varnish from dead fuel, then I de-rusted it with citric acid. It looked like new when it was finished.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed May 03, 2017 9:32 pm
POR 15 tank repair kit...I did both my tanks with this
http://www.ppcco.com.au/por19.html
Jenk.
PostPosted: Thu May 04, 2017 9:29 am
I used CLR in a tank that I had to clean not to long ago and it worked wonders.
