It is currently Sun Jul 20, 2025 5:11 am
Post new topic Reply to topic  [ 52 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Original underlay
PostPosted: Thu Aug 03, 2017 8:32 am
Hi
Would anybody have some photo's of the original underlay which is used in the Australian mini's.
Really looking for Cooper s and Clubman GT.
I've done a search and there are some photo's on Ausmini but also some have gone with photo bucket issues.
I have purchased some new Jute and Hessian to create an original look and have completed the inner boot lid area as a starting point. Very happy with finished product. Next is the under bonnet fire wall item.
Hope to get enough photo's to complete all the known area's. Have some original headlining now so will be able to replace that area as well.
The photo's will help with the correct shape/size and locations.
Cheers :)
 Post subject: Re: Original underlay
PostPosted: Thu Aug 03, 2017 1:36 pm
Firefirey wrote:
Would anybody have some photo's of the original underlay which is used in the Australian mini's. Really looking for Cooper s and Clubman GT. I've done a search and there are some photo's on Ausmini but also some have gone with photo bucket issues.
If you adopt Google Chrome as your browser you can add an extension that effectively reinstates the images, so everything is back how it was - https://chrome.google.com/webstore/deta ... aedg?hl=en
The most extensive thread with details of sound insulation is this one - viewtopic.php?f=2&t=89101
You probably know that the under bonnet firewall insulation is black vinyl with hessian backing, as pictured in the thread referenced above.
Below is a table showing the part numbers for the various items of carpet and insulation in Oz Minis. Vinyl floor coverings are listed in another table. I have BMC engineering drawings for some of these. If you put together a list of the items you are trying to replicate I'll see if I have the matching drawing.
PostPosted: Thu Aug 03, 2017 1:56 pm
Don't forget these ones
Simonw
Brisbane QLD
1st car - 1964 Mini Panelvan 850
Previous - 1978 Leyland LS 1275 Gold
- 1969 Mini K
PostPosted: Thu Aug 03, 2017 7:12 pm
Thanks for that information Doug and I'll try to get goggle chrome sorted.
At the moment I'm trying to locate some vinyl that matches to original patten ( I have a damaged one to copy from but only a small piece.) The patten is very fine.
I will take you up on the offer of the drawings and will let you know which pieces I will need. Once again thank you for your expertise and knowledge. It is very much appreciated. :) :)
Simonw:
Thanks for the photo and also much appreciated :).
That's very interest with the trim panel - I haven't seen that before and I can remember that my Cooper S trim panels had polystyrene blocks as packing glued to the inside to stop movement. I have kept the original trim as it is in very good condition.
Has any body else seen this? :shock:
PostPosted: Thu Aug 03, 2017 7:44 pm
I had a 65 Deluxe and 66 Cooper S that both had the thick jute wads glued onto the back of the rear quarter panel trims, as per Simonw's photo. I think I even still have the Deluxe trims in the back of the garage with a pile of other trim stuff...
PostPosted: Thu Aug 03, 2017 9:34 pm
Confirm same stuff on my 66 Cooper S....
Cooper S Mk2
Cooper S Mk1
PostPosted: Fri Aug 04, 2017 7:32 am
Could anybody confirm BBY755 and Simonsw findings on the later 69 or 70 models
Cheers for your reply's :)
PostPosted: Fri Aug 04, 2017 3:36 pm
I'll get some photos of mine and put them up here.
71 Clubman GT
63 Morris 850
66 Mk 1 Cooper S
PostPosted: Fri Aug 04, 2017 5:05 pm
Cheers Thank you. :)
PostPosted: Sat Aug 05, 2017 5:23 pm
Just removed the door cards on my Sept 1970 S. Glued to the base of the cards are three strips of polystyrene butted end to end, although one strip was broken and unglued and a couple of strips were missing. This looks original to me but it would be nice to see other examples from unmolested cars just to confirm.
Imperial dimensions of the foam strips is 8" x 1 3/4" x 5/16".
I think I'll replace the polystyrene with some foam rubber equivalent and just hope the concours judges don't check. :D
PostPosted: Sat Aug 05, 2017 6:58 pm
Doug :D. Yes that is the same as my 1970 Cooper S. Front door panels. I have replaced the old polystyrene with new and the same dimensions. Would say that this was an original procedure from the factory for the later models and the earlier models used the hessian/jute. Looks like they used the packing to make the door trim fit tight up against the inner pocket trim for a neat looking fit.
Has anybody got some more photo's of the hessian/jute used in these models - all locations.
Cheers.
PostPosted: Sat Aug 05, 2017 9:26 pm
Same as mine 3/70 Cooper S. I was going to use some closed cell high density foam of similar thickness. Rear panels don't have any hessian/jute like simonw's picture, or glue marks on them in those areas. I have the whole interior out of mine, if I have time tomorrow, I will grab it out of storage and take some pics for you.
PostPosted: Sat Aug 05, 2017 10:05 pm
Cheers ausdino.
Trying to get some idea's of the hessian/jute underlay in all area's.
Would you have the underlay for the lower boot area :)
I'm not sure if the Mk 2 Cooper S had the underlay in the lower boot floor from the factory?
PostPosted: Sat Aug 05, 2017 11:56 pm
Sorry, mine did not have the boot area section when I bought it. I have seen some pictures on this site though. My original mk2 I bought in 1976 didn't have it either, whether the previous owner had removed it, I don't know. I was the second owner.
PostPosted: Sun Aug 06, 2017 9:18 pm
This is all the pieces I have out of my car.
Users browsing this forum: No registered users and 70 guests
