It is currently Sun Jul 20, 2025 5:32 pm
PostPosted: Thu Oct 19, 2017 9:27 pm
Harley wrote:
hpal wrote:
Could some kind person please measure their 8.4" style disc for me so I can see if this one is the same??
51mm for the length you have indicated in your photo above.
Assembled, it should be like this (simplified):
Thanks Harley, you are on the money I think, when I can I'll measure the disc I have but I'm sure it's more like 70-80mm deep. My googling revealed something interesting too. The hub has a number on it of BTA362, google says this is an MG1100 swivel hub! The butcher who has the car previously must have tried to put the 1100 brakes on as well as the 1098 engine which is in it! SOOOOOOO Dodgy.
So, I need two new mini disc brake hubs, I have bearings already I'll just tap them out of the morris hubs, I need some 8.4" discs and pads, and I need to make sure of the calipers I have and make sure they are mini not 1100 which I may need some help with. Or If I'm starting from scratch I can use 7.5" or 7.9" or whatever I want if I need new calipers anyway, thoughts?
The old disc I have has a casting number of AYQ4014 which I can't find any info on.
PostPosted: Thu Oct 19, 2017 9:56 pm
Looking at the Australian Morris 11100 parts book...
BTA362 is the Morris 1100 swivel hub.
AYG4014 is the Morris 1100 disc. (Australian part)
I'm thinking you might need to change the calipers too, the bolt holes might be spaced differently.
PostPosted: Fri Oct 20, 2017 12:31 am
Now I wonder how I can ascertain whether my calipers are off an 1100 or a mini??
PostPosted: Fri Oct 20, 2017 7:03 am
OR...(for example)
http://minisport.com.au/disc-brake-kitsaupgrades
PostPosted: Sat Oct 21, 2017 9:59 am
And probably new wheels... the stud pattern is different.
Sent from my Nexus 5X using Tapatalk
Don't listen to what I am saying... just understand what I mean.
PostPosted: Sat Oct 21, 2017 12:00 pm
Ordered new 8.4 discs and pads, new hubs, new calipers. Wow, didn't see that extra expense coming!
PostPosted: Sat Oct 21, 2017 12:02 pm
Yep got new wheels as I needed them anyway, there were only 3 mags on it when I got it, same stud pattern as there are mini drive flanges on it already.
Users browsing this forum: Majestic-12 [Bot] and 79 guests
