It is currently Sun Jul 20, 2025 6:00 pm
 Post subject: Gear shift base
PostPosted: Sat Oct 21, 2017 12:37 pm
On the brochure for the Mini K, you can clearly see a squared off base for the gear shift rubber boot on the floor. Did all Mini’s have this part or was it a "K" detail?
1970 Mk2 Cooper S
 Post subject: Re: Gear shift base
PostPosted: Sat Oct 21, 2017 12:54 pm
It's just the profile of the rubber mat as fitted to the Mini K, and others. The carpet on your Cooper S would sit around the rubber gaiter and not look as squared off as the rubber mat. The floor pressing underneath is the same across all the models.
PostPosted: Sat Oct 21, 2017 1:02 pm
Thank you for the fast reply.
I thought as much as I’v never seen anything like that before.
1970 Mk2 Cooper S
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 79 guests
