It is currently Fri Jul 18, 2025 1:34 am
 Post subject: Fuel tank
PostPosted: Fri Oct 27, 2017 4:29 pm
Daffodil 1275
I have attached some pics I hope to get advice on... sorry if you have to stand on your head to see them! Is this little tube the fuel breather tube? Where would it be connected to the fuel tank (cooper S). Also are these cables on the tank the battery earth cable & electrical connection? What effect is there if they are not connected ? The one that is off in the picture seems to be like that whenever any work is done on the Mini
Life advice
Don't wait for the storm to pass
Learn to dance in the rain
OR
Go drive your MINI
 Post subject: Re: Fuel tank
PostPosted: Fri Oct 27, 2017 6:06 pm
The left tank vent pipe plugs into the top of the tank and then crosses over to the opposite side of the car and goes down along the seat back and out through a hole in the floor next to the positive battery cable.
It is normal for the positive battery cable to hang down a bit, however it should be held by a P clamp like in this photo.
PostPosted: Fri Oct 27, 2017 6:25 pm
I looked into my right hand tank today and noticed there is an internal filter attached to the lower joining pipe. Is this normal?
PostPosted: Fri Oct 27, 2017 6:58 pm
Yes that's normal. Minis have a gauze mesh filter on the pickup pipe inside the fuel tank. They also have a gauze mesh in the fuel pump. They did not come out with any other filters.
PostPosted: Fri Oct 27, 2017 10:29 pm
Daffodil 1275
I have turned the photo up the right way & marked the tube In question. I thought it may be the breather or overflow
Life advice
OR
Go drive your MINI
PostPosted: Fri Oct 27, 2017 10:34 pm
That is the breather vent tube from the top of the left hand tank. It exits the floor pan next to the positive battery cable.
Your loose wire is the earth for the fuel tank sender. Just plug it back into the empty terminal on the sender unit.
Like this
PostPosted: Sat Oct 28, 2017 7:35 am
It's important that both tanks have the breathers fitted and that they cross to the opposite side. If not fitted or not crossing then there is the risk that if the tanks are full and you park on a sideways slope, the fuel will drain from the hi tank to the low tank then overflow out the breather.
PostPosted: Sat Oct 28, 2017 2:29 pm
Daffodil 1275
I think this is right in my car. I have attached photos of the tubes & tanks in boot. I had an MG that had that issue on a slope. Mini is much better!
Life advice
OR
Go drive your MINI
PostPosted: Sat Oct 28, 2017 2:32 pm
Daffodil 1275
Tank photos
Life advice
OR
Go drive your MINI
PostPosted: Sat Oct 28, 2017 3:56 pm
69Cool wrote:
Tank photos
Yes that is the correct way to prevent fuel overflow.
That is some serious sound proofing. Its a shame they didn't do under the parcel shelf where quite alot of the noise comes through into the cabin.
PostPosted: Sat Oct 28, 2017 4:11 pm
Daffodil 1275
Yes that was my handiwork & I didn’t realise about the parcel shelf
Life advice
OR
Go drive your MINI
PostPosted: Sat Oct 28, 2017 8:39 pm
The factory actually added soundproof to the underside of the parcel shelf, the boot floor and inside the boot lid ....just on the cooper S. It is actually pretty effective. On some early cars they even added it to under the rear seat base.
PostPosted: Sun Oct 29, 2017 4:35 pm
Daffodil 1275
It’s funny, having the soundproofing doesnt make it any easier to hear the music.
Life advice
OR
Go drive your MINI
PostPosted: Sun Oct 29, 2017 5:21 pm
By "music" do you mean the exhaust note? That's the only music that comes from my car.
PostPosted: Sun Oct 29, 2017 5:47 pm
Daffodil 1275
I enjoy the exhaust note too but also play music which I can only hear driving around town. Once the speed gets up the engine, exhaust etc drown out the vocal music haha
Life advice
OR
Go drive your MINI
