It is currently Mon Jul 21, 2025 8:29 am
 Post subject: Mini or Brick
PostPosted: Mon Nov 27, 2017 4:33 pm
Hello All,
Just fitted engine and subframe as a unit .Placed a couple of planks under the car using 4 jack stands and a jack. lowered the body over the subframe motor unit. Went well got 4 bolts into the subframe , kicked the caster platform away from the subframe then the front of the car tilted down like a seesaw. The wife came out and suggested bricks in the boot, good idea. blanket and 12 bricks fixed the problem. I now have the car on 4 secure stands. Goods use of bricks.
P7676.
 Post subject: Re: Mini or Brick
PostPosted: Mon Nov 27, 2017 5:43 pm
Incorrect front panel?
PostPosted: Mon Nov 27, 2017 6:24 pm
FRONT PANEL IS CORRECT 1970 CS and it fits PERFECT P7676
PostPosted: Mon Nov 27, 2017 6:25 pm
PostPosted: Mon Nov 27, 2017 6:28 pm
nice work ;)
PostPosted: Mon Nov 27, 2017 6:57 pm
Where did you get the repro front apron from?
PostPosted: Mon Nov 27, 2017 7:06 pm
Yes looks to have the wrong number plate brackets as per English mini :shock: ( British Heritage panel ?)
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Mon Nov 27, 2017 7:27 pm
I think these are the main areas that need to be looked at if you want to change the aftermarket apron back to original.
PostPosted: Mon Nov 27, 2017 7:37 pm
Oh dear, worry, worry...
HI All
Why is it when some body up loads a photo of their mini that they are restoring to the way they want it people have to get on here and start picking on it?, does it really matter if it had square head lights and a KIA front on it? he is doing a really good job on it, and it is looking really good, very well done p7676 keep up the good work it will look really good when finished.
Jealousy is terribly thing.
Graham Russell
PostPosted: Mon Nov 27, 2017 7:49 pm
GR wrote:
HI All
Graham Russell
Totally agree. Thats why I said "if".
Not everyone wants to restore their car back to original. I just saw his incorrect comment about it being the correct front panel and offered a photo of the areas that need to be looked at if he wants to bring it back to original.
No haters here
PostPosted: Mon Nov 27, 2017 7:52 pm
GR wrote:
HI All
Graham Russell
No jealousy involved :? personally I just like to see a nice restoration done correctly , and also for future value , and I would think everyone likes to know the correct parts to be used even if they don't want to go that way. I am currently restoring an XD and XE Falcon both factory 351's and I certainly enjoy the help of the Ford Forum in pointing out any thing I am doing that is incorrect . If you just want a nice restored mini with no regard for originality , that is totally up to you , after all you are paying out the cash and doing the restoration , I have done so myself in the past , so good on you.
Just my 2 cents worth
1965 Morris 850
1977 Leyland LS
PostPosted: Mon Nov 27, 2017 8:05 pm
I bought the car for $6000.00 about 16 years ago Just got it out of storage, something to keep me busy. The car has been sand blasted new panels fitted using an inverter spot welder, metal finished no body filler 2 pack epoxy primer 2 pack PPG paint. I will have it completed soon . I may even drive it sometimes I don't show cars as I cant see the point. When I die someone can have my cars. I do all the work except the engine rebuild .P7676
PostPosted: Tue Nov 28, 2017 6:44 am
Mine has pommy sills Better than the rusty ones they replaced and unless you go looking who would know or care
PostPosted: Tue Nov 28, 2017 6:50 am
You better sack the panel better for being slack lol
PostPosted: Tue Nov 28, 2017 6:56 am
GR wrote:
HI All
Graham Russell
I am not jealous in any way and if the guy is happy with it thats his decision I was only mentioned it other people that may do a restoration to know that there's differences in the rover panel if there chasing 100% factory
Users browsing this forum: justminis and 92 guests
