It is currently Wed Jul 09, 2025 2:47 am
 Post subject: The “Remrod”
PostPosted: Thu Dec 07, 2017 2:30 pm
Well I’ve been working on this idea for over a year now and as I’m starting to make a prototype I thought I’d start a thread for some updates as I go and I’m keen for some constructive criticism too.
A bit of an explanation of what I’m try to achieve might help...
The gearbox fitted to my panelvan as I purchased it is the trusty old rodshift unit. As my van is a 66 the tunnel has no provision for a rodshift and as a result was very poorly installed, floppy, and gradually destroying itself due to the terrible angle of the shift rod.
So, I decided some time ago to try and fabricate a remote style housing for the rodshift box that will solve all of my problems. Hence “Rem-Rod”!
I decided from the start it must,
*Be able to be fitted and removed with the engine In situ.
*Be strong enough to act as a suitable “torque arm”.
*Not be any lower than the original remote housing.
*Allow room for a 2” exhaust in the tunnel.
*Weigh the same or less than the original remote.
If the prototype I’m building is successful, I will have all the info I need to draw it up in cad for plasma cutting. Ultimately I’d like to fabricate it from 304ss.
Silas
 Post subject: Re: The “Remrod”
PostPosted: Thu Dec 07, 2017 2:45 pm
great idea :D
PostPosted: Thu Dec 07, 2017 4:41 pm
simon k wrote:
great idea :D
Thanks :D
And this is the jig I’m building it in...
PostPosted: Thu Dec 07, 2017 5:20 pm
Good idea, can't wait to see it progress.
PostPosted: Thu Dec 07, 2017 6:28 pm
Wow, great idea and great work so far. Thanks for sharing.
I wonder if there's a wider demand for such a product? You may have to give your day job away.
PostPosted: Thu Dec 07, 2017 6:51 pm
Even if you just had a 90 degree angle on the angle you have it now and across the bottom face it might provide enough strength?
It reminds me a bit of the PPF bracing under an MX-5
PostPosted: Thu Dec 07, 2017 6:57 pm
Thanks, if it goes well enough I’ll look at making more. I’ve been thinking that basically any rodshift mini could use something like this, less wear- no additional top engine mounts needed- and hopefully a much sharper feeling shift too.
PostPosted: Thu Dec 07, 2017 8:05 pm
Thanks for the input Timmy!
The angle idea is something that I pondered for some time and may still try at a late date.
My only reservations are that,
1- The shifter will only be supported at the rear on the right side.
2- The size of angle will have to be substantial to counter any twisting or lateral movement.
PostPosted: Fri Dec 08, 2017 9:47 pm
This is a great idea. Anything that strengthens the rear of the rod and the way it is mounted, would be an improvement. I'd buy one for a reasonable price and will keep watching.Cheers Paul M
PostPosted: Mon Dec 11, 2017 8:09 am
Love a good C.A.D. template.
Nick
PostPosted: Mon Dec 18, 2017 9:43 am
Don't make it in 304SS use something in balance on the galvanic table.
PostPosted: Tue Dec 19, 2017 1:25 pm
Make it from steel and hot dip galvanize it, it'll be a nice sacrificial anode. :)
Mind you it won't corrode anyway with the oil fog that trails from an A series.
Good idea BTW. ;)
PostPosted: Tue Dec 19, 2017 5:55 pm
Silobin, I would think that these would sell well. Don't need to be fancy, just work by adding stability. I definitely want one, so please let me know when one is available. And where is Woodhouselee?
Paul Miniken
PostPosted: Wed Dec 20, 2017 8:04 am
This is a very good point, thanks besser! Maybe I’ll look into powder-coated or hdg steel as doc says.
Thanks for the input folks :D
Paul Miniken
Thanks Paul, I’ll be sure to let everyone know!
(P.s. woodhouselee is between goulburn and crookwell, NSW)
PostPosted: Wed Dec 20, 2017 5:17 pm
Thanks mate, I go to Canberra a few times during the year, so now know where you are. Any timetable on a prototype?
Paul M
