It is currently Sun Jul 27, 2025 3:47 pm
PostPosted: Sun Jun 05, 2005 12:31 pm
ok so ive got an 1100 got me some lcb,s and put em on twin inlet manifold ,built up some twin carbs,correct needle springs ,bolted em on turn the key,push the button and the thing just screams its little head of as if at full throttle ,choke set throttle closed , although doesnt make any diff . no floats sticking i have read manual and checked in vizards but cannot rectify problem only way it will run is by turning key on and off before revs get high so pistons dont fly through bonnet have set mixture and played around with that thinking it was too rich but even screwed to top does the same can ny bdy help me or shed some light on what i have overlooked ????? can ran fine with single .
1. how do i get it to 'tick over nice"
2. what else can i try
3. how far should i be able to throw 5/8 spanner
PostPosted: Sun Jun 05, 2005 1:39 pm
could be the butterfly/s sticking open
PostPosted: Sun Jun 05, 2005 1:57 pm
Yeah, sticking butterfly probably. I've thrown spanners into my angry neighbours garden before. Full on chucked them over the fence.
Jonathan
PostPosted: Sun Jun 05, 2005 2:13 pm
hmmm checked that butterflys closed / ie doesnt make any difference whether throttle is open or closed still races ??????/ but thanx muchness keep tryin
PostPosted: Sun Jun 05, 2005 3:22 pm
You said you built up a set of SUs didn't you?
I once made the mistake once when I rebuilt a set, I put in those replacement butterfly bushes on the spindles but didn't push them in far enough so air went around the butterfly when I tried to run the car. Took me a while to spot that one.
PostPosted: Sun Jun 05, 2005 5:40 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i know it may sound silly but are the dash pots filled with oil ???
and are the needles sitting back into there seats corectly ??
makka
PostPosted: Sun Jun 05, 2005 7:05 pm
If you rebuilt the carbs did you maybe fit the butterflys the wrong way? Easy to do... :cry:
PostPosted: Sun Jun 05, 2005 7:07 pm
makka
not silly can happen nope not that ! but read on
PostPosted: Sun Jun 05, 2005 7:08 pm
makka
PostPosted: Sun Jun 05, 2005 7:14 pm
makka
well took off the twins got out the angle grinder and cut the one piece manifold in half to use the inlet part put on single su and starts like a kitten and even purrrs obvously the twin setup hadnt sat in the shed long enough !!!! so ive hung them up to mature a little !!!! and will come back to them in the warmer months when its no so bloody cold workin in the shed ect and my sanity has returned .
Users browsing this forum: mincs1 and 102 guests
