It is currently Wed Jul 16, 2025 8:21 pm
PostPosted: Sun Aug 11, 2019 8:06 am
Hi all,
I have been on the hunt for driving light mounting bracket, but it seems that I have NFI what im actually looking for..
I have had the image below saved to my phone for years as a bit of inspiration for my own car & I really like how the middle 2 lights sits slightly higher than the outer 2.
If know the name or style of this bracket my google search history would appreciate having a rest.
Also if you have driving lights mounted on your roundnose I'd love to see pics!
Thank you
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Sun Aug 11, 2019 8:59 am
Online
I think that’s the “works type” spotlight bracket
http://www.minispares.com/product/Class ... A1101.aspx
I’ve got some a spot/fog pair of lamps that mount directly to the grille :)
PostPosted: Sun Aug 11, 2019 9:24 am
Thanks mate, yeh I have seen those ones on mini spares but they apparently don't fit with the overriders, so guessing it not those ones on this car..
Sent from my SM-G960F using Tapatalk
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Sun Aug 11, 2019 11:06 am
Here's the light bar I made, it used thick plate bolted to the subframe and comes up through the grill, the centre support you can see that goes around the bumper adds a lot to the stability. I didn't like how most of the similar light bars available needed holes drilled in the front.
Roads need more corners
PostPosted: Sun Aug 11, 2019 11:56 am
Online
There’s a photo of one here, it doesn’t look much more than two foglight brackets with a bent piece of bar in the middle?
http://www.theminiforum.co.uk/forums/to ... rk/page-20
PostPosted: Sun Aug 11, 2019 12:18 pm
I have made a 'factory style' bar and brackets similar to "fuzzy-hair-man": bolts to subframe, under grill, no holes in stone tray.
Have also made a modified version with just the brackets bolted to the subframe, under the grill and resting on the bumper bar. Again, no holes in the bodywork.
PostPosted: Sun Aug 11, 2019 12:56 pm
NSW Police mounted most driving lights directly on the panel behind the bumper. To improve rigidity and hence lessen vibration a large washer welded to some threaded tube was installed in each hole, with the Hella driving light stem in the middle.
PostPosted: Sun Aug 11, 2019 1:55 pm
Here's the setup I run on my roundie van. I picked up the vertical brackets from a mate years ago so no idea who made them originally but they mount off the bottom valance and the bonnet slam panel. I then made up a cross bar for the centre two lights. Everything is mounted nice and solidly and having the driving lights up slightly higher gives a good bit of range and spread at night.
Mister White Keys
"He who has the most toys, Wins"
1963 Austin Countryman Woody
1964 Morris 850 Van
1967 Austin Countryman
1975 Range Rover 2 Door
2004 Subaru Forester XT
2015 Potts Teardrop Camper
RIP 1990 Citroen BX 16Valve
