It is currently Sun Jul 20, 2025 5:36 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Cylinder head
PostPosted: Sun May 10, 2020 11:09 pm
Ness_c7 wrote:
Hey thanks for the info good 2 know so i have a figure in mind when searching for one! Wat about the 206? Probly no chance of finding one as their 2 rare?
Sent from my SM-G973F using Tapatalk
MKO had the 295 for $660 but are out of stock. https://minikingdomonline.com.au/produc ... c-engines/
The 206 is rare. You may not find one.
PostPosted: Sun May 10, 2020 11:11 pm
Yeah contacted them last week no more in stock. Thanks 4 ur help thou appriciate it
PostPosted: Mon May 11, 2020 10:30 am
The other thing with the 295 is that you have to have a conversation about compression with the machine shop. GR flat top pistons can solve the problem. To do it right and get the full potential requires parts to be matched during the engine build.
Neil
PostPosted: Mon May 11, 2020 10:36 am
"Exhaust gas flows anticlockwise in the southern hemisphere."
Gold!!!!
PostPosted: Mon May 11, 2020 10:40 am
Hypatek make a flat top piston too. See Ebay. FYI, I'm getting a 295 from the US of A landed for under $500. Standard and has been crack tested.
PostPosted: Mon May 11, 2020 10:52 am
I have built small bore motors with both Hypatec and Russell Engineering pistons.
Both are good.
But if building a 1098, the Russell engineering ones have thicker ring lands. Don't break as easily. They have 1 less compression ring.
PostPosted: Mon May 11, 2020 10:56 am
Wow cheap! What size engine do u have 998? Who's building your engine for you?
PostPosted: Mon May 11, 2020 4:57 pm
Doc my flat top Hypatec pistons have two compression and one oil ring.
I'm building an 080, 998. Building it myself.
PostPosted: Mon May 11, 2020 5:27 pm
Well sorry TK, my bad.
I was thinking of Hypatec dished 1098 +.060 vs GR's flat + .060s.
The Hypatecs had broken ring lands so I fitted Graham's flat tops. ;)
PostPosted: Mon May 11, 2020 5:52 pm
All good Kev
PostPosted: Mon May 11, 2020 5:57 pm
Oh dear, worry, worry...
Hi Ness-c7
I think I have about 6or 8 295 heads left,i would have to get them out and check them out.
One thing with the 295 heads the valve seat is very thin .040 tho or 1 mm with no metal to get a wider seat with the std valve, and with the unleaded fuel the valves really start to pull down into the head.
You are much better off fitting a larger inlet valve which gives you a much better valve seat, better flow better performance have a look at my website.
If you are interested in a head give me a call 0296302195.
Graham Russell
PostPosted: Mon May 11, 2020 6:00 pm
Graham Russell
LOL
PostPosted: Mon May 11, 2020 6:14 pm
Hi TK
You may like to know that I designed the 998 pistons for Precision but they changed the design a little, they dropped the ring package down from the top of the piston be cause there ring pack would not handle the heat.
They also made the piston about .250 tho longer more drag , heavier piston.
I also designed the 73mm and 73.5mm pistons that's why the 998 and 73 /73.5mm have oil holes drilled behind the oil ring not slots bad design.
There pistons are a cheaper piston than mine I don't have the buying power they have but they are a good piston.
My rings are a much better ring for both the small bore and 1257, but there rings do the job.
Graham Russell
PostPosted: Mon May 11, 2020 6:35 pm
Hey Graham, I wasn't questioning your pistons or rings. I was just found your offer funny. Sorry.
PostPosted: Mon May 11, 2020 7:17 pm
Hi Richard
I wasn't dealing with the piston company I was dealing with precision, at the time I started a class for minis called mini one thousand racing and we could not get 998 flat top pistons at the time.
That's when I approached precision to have them made, and they asked me what I had in mind so I did some drawings and faxed the to them, they then asked what other sizes would be a good selling piston that's when I gave them the 73/73.5 size.
All went well for a while till I got burnt buy them that's when I got my own pistons made and rings.
If you know any thing about rings you would see the difference in the quality of the rings.
As for the over priced gold plated Thailand rings my rings are $80 a set how much are yours the last set I bought from precision were around $100.
A lot of good things have come out of back yards right round the world.
If I still have the faxes I will send you a copy.
Graham Russell
