It is currently Sun Jul 20, 2025 10:22 am
 Post subject: Boot Lid Weather Seal
PostPosted: Fri Oct 07, 2022 8:28 am
I guess many of you have done this job, that is replacing the boot lid seal. I am have difficulties. Any thoughts.
PostPosted: Fri Oct 07, 2022 8:38 am
I have never been able to use those clips with the boot seal. You get a few on, thinking you are winning then the rubber slips off.
I end up gluing the strip on. And the clips are quite expensive, too.
PostPosted: Fri Oct 07, 2022 8:50 am
use contact cement. easy job
PostPosted: Fri Oct 07, 2022 9:23 am
The best way I found to put them in was with a 90 degree spot weld chisel. That was after I destroyed a lot and the seal other ways.
Test... Don't Guess
PostPosted: Fri Oct 07, 2022 12:40 pm
I just pushed them in with a pair of long nosed pliers broke a couple but don't remember having a lot of difficulty
PostPosted: Fri Oct 07, 2022 12:54 pm
Yes. But considering everything you've been through, this would have seemed an 'easy' job!
Users browsing this forum: Scoop and 77 guests
