It is currently Thu Aug 14, 2025 9:47 pm
PostPosted: Sat Jan 07, 2023 9:52 pm
Ok.. so dumb question..
I went to try replacing the tie rod rubbers today.. but when I tried to remove the bolt from the tie rod (at the hub end)... it seems too big to be removed. When I try to lift it, it just fowls the CV boot. By the time the bolt hits the CV boot - I would estimate there's around 5 mm left.
Is there any trick to getting it out?
PostPosted: Sat Jan 07, 2023 9:55 pm
It should only need to be long enough to get a nut on the end. If you really get stuck you could pop off the ball joint to give more room
PostPosted: Sun Jan 08, 2023 7:00 am
Try jacking the hub up, it should open up the gap enough to wiggle the bolt out.
Users browsing this forum: No registered users and 278 guests
