It is currently Sun Jul 13, 2025 2:27 pm
PostPosted: Sun Aug 27, 2023 11:51 am
I have tried the current version (rubber type) and they are useless. They curl up and the car has only had fuel in it for a month.
Is there a better alternative, such as the original cork type seal and where can I get them.
PostPosted: Sun Aug 27, 2023 11:55 am
Make one out of sheet cork.
PostPosted: Sun Aug 27, 2023 12:52 pm
Took cap with me to local Bunnings plumbing section. Found this rubber seal, been on car for 4 years. Better quality rubber than expected.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Tue May 28, 2024 11:14 pm
Found my fuel caps were leaking fuel, so decided to try out CGO recommendation of a toilet cistern washer. The washer that seemed to fit the dimensions were for Johnson and Suisse systems. Here's a link https://www.bunnings.com.au/kinetic-bla ... r_p4920270
The washers are thicker than 2.x mm rather than 1.4mm, but with a little grease around the lip of the tank they fit ok.
Thought it would might be useful to share incase it helps.
PostPosted: Wed May 29, 2024 10:06 am
That is interesting - I have a few of those washers..
I'm using fuel caps that were for a valiant or something, they've lasted really well.
