It is currently Mon Jul 21, 2025 1:34 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jun 07, 2005 9:42 pm
Simple wrote:
So would the axles still turn coming out of the gearbox if in gear?
I will have a better peak tomorrow night. Thanks for all you help. I hope I can still make Saturday morning at RE.
If I do, I probably won't have the mini.
I would put the front of car on axle stands, put in 1st gear, motor off- then see what does/doesn't turn.
If you get someone to hold one wheel and you try to turn the other, it shouldn't turn. If you just turn one wheel the other should spin in opposite direction if the diff gears are intact.
PostPosted: Tue Jun 07, 2005 10:04 pm
Thanks I will give that a go and see what happens.
Daily Driver - Yellow Devil 76 Clubman
Restoration Project - Primer grey 66 Morris Mini Deluxe
PostPosted: Wed Jun 08, 2005 10:59 pm
OK I had another quick look tonight, just don't have much time of an evening, and it seems the diff is working as the Doc said it should. That is some good news. Does this also mean that the clutch is working fine as it found first gear ok?
If that is the case I just have a CV Joint and drive shaft to change out.....
I will be at GRs if that is all there is to do..
Is there anything else I should look at after a failure like this... Wheel bearings or anything?
PostPosted: Wed Jun 15, 2005 9:47 am
For those that ever encounter similar symptoms, it turned out to be that the drive shaft had some how come out of the CV joint.
Gave the drive shaft and CV a good clean, made sure that there were no broken bits or problems, and whacked it back together.
So far haven't had a problem. Touch wood
PostPosted: Wed Jun 15, 2005 8:51 pm
Maybe it wasn't right into the CV...
If it happens again, replace the wire circlip in the end of the driveshaft... :wink:
PostPosted: Fri Jun 17, 2005 8:38 am
Are these wire clips easy to come by? Where can I get one because it happened again..... :(
Thanks for your help.
PostPosted: Fri Jun 17, 2005 8:57 am
PostPosted: Fri Jun 17, 2005 10:59 am
Simon,
If its a buggered (Worn round) groove in the CV where the clip slips in, offer is still there I have drum brake front hubs complete with CV's you can have though I want the drive shafts.
Dino.
Over 1,000,000Km, but now my retirement restoration project
PostPosted: Fri Jun 17, 2005 7:28 pm
Wow, it happened twice in a minute!
Try Karcraft http://www.karcraft.com.au They have them listed in their price list (37H8706) $3.58
PostPosted: Fri Jun 17, 2005 7:32 pm
Karcraft are not open Saturdays, but Mini Suzuki Spares in Prime Drive, Seven Hills carry them and they are open. :wink:
PostPosted: Mon Jun 20, 2005 8:15 am
Thanks guys.
It was some poor workmanship on my part. :oops:
This time I made sure that the drive shaft was ALL the way in the CV joint :oops:
Users browsing this forum: Bing [Bot] and 77 guests
