It is currently Sat Jun 28, 2025 9:49 am
 Post subject: Seats
PostPosted: Sun May 04, 2025 8:54 pm
What comfortable seats fit in a mini, alternatively is there a way of making seats more comfortable.
As I get older I find I need more comfort.
Cheers Dave.
 Post subject: Re: Seats
PostPosted: Mon May 05, 2025 12:04 pm
*In jest* - https://www.youtube.com/watch?v=LVSLLWXdKV0
Doubt it's ADR compliant though.
Nick
PostPosted: Mon May 05, 2025 2:26 pm
Cobra seem to be a popular conversion
;-) Pete...
____________________
1968 Deluxe 1275
1969 Deluxe 'Scruby' 998 Looking for a roof skin...
PostPosted: Mon May 05, 2025 4:41 pm
As I get older, I find I just need more seat!
Cobra brand and other similar seats are a bit of a tight fit and the high sides require yoga positions to get into and out of them.
I'm thinking of reupholstering a pair of tombstone type seats to replace the original low backed.
What regulations or ADRs apply to alternative seats and mounting designs? I have thought about seat replacements but have assumed it would cause less of an issue if the seats were based on the original seat frame and using the original attachment points.
PostPosted: Mon May 05, 2025 4:58 pm
Yep Mr Bean is a classic. Also see the christmas episode for how to load up a mini.
Cheers Dave.
PostPosted: Mon May 05, 2025 5:02 pm
You may be on to something Bill, maybe it is just more seat. I also wonder if sitting position is a comcern. There are some cobras that dont have high sides but any cobra seat seems to have the price of a new car attached. I thing cobra and other seat makersdo fitting kits for the mini so should be legal.
Cheers Dave.
PostPosted: Mon May 05, 2025 10:37 pm
Back in the late 70's/early 80's, I had recliner Recaros in my Mk2 S. They fitted well even with Bond half cage, you could still get to the handbrake. Only problem I can recall was tilting them forward with the mesh head rests. I'm putting Autotecnica low backs in my current car.
PostPosted: Tue May 06, 2025 9:07 am
I have some SAAS seats fitted to the van. They are ADR compliant, but I had to have them engineered due to requiring new mounts to be fabricated, so be mindful of that if going for something that is not a direct bolt in fitment.
67 Van, 1275cc
PostPosted: Tue May 06, 2025 9:13 am
Thanks all. Some food for thought. For a start I may just replace the foam in the seats with some proper seating type foam. I just need to decide what is the best product for the job.
Cheers Dave.
PostPosted: Wed May 07, 2025 12:26 pm
I purchased foam from Clark Rubber. They have a good range. Not cheap for a piece of foam but did a good job.
PostPosted: Wed May 07, 2025 12:46 pm
Sometimes you can be lucky in the offcuts bin at Clark Rubber, they are really cheap.
Repairing your old seats makes a huge difference, for mine I replaced the old elastic with new upholstery webbing & some new foam. I woud suggest to make the webbing as tight as you can
PostPosted: Wed May 07, 2025 6:56 pm
Thnks for the advice 9n the webbibg, I may as well do all I can while at it.
What specific foam did you use, Clarks seem to have heaps of different types.
Cheers Dave.
PostPosted: Thu May 08, 2025 10:15 pm
I refurbished my front seats last year. I think I used a high density seat foam
See https://www.clarkrubber.com.au/products ... oam-29-200
Also these videos were very helpful
https://www.youtube.com/watch?v=OyISLClxdkA&t=1374s
https://www.youtube.com/watch?v=viIrNDhrnE8
I used a bread knife (bought on FB marketplace) to shape the foam
PostPosted: Fri May 09, 2025 8:23 am
Thanks for tnat.
Cheers Dave.
PostPosted: Fri May 09, 2025 9:12 am
Some good upholstery videos on this channel too:
https://www.youtube.com/@oldschoolautoupholstery/videos
;-) Pete...
1968 Deluxe 1275
