I_AM_THE_WAHL wrote:
ok still working out niggles now is it nessasary to go for double valve spring or what should i go for
also got this as a reply from wade cams
re cam sugestion
446B
Gday
I've got the 446B cam and I'm very happy with it. I think from previous conversations with DrMini the specs are similar-ish to the RE-13 cam. It probably doesn't rev quite as high though. Its got less lift (.425" with 1.5's) and a fraction longer duration (290* in and ex)
With the 1.5 rockers it pulls 7000rpm easy - I haven't tried to go much more than that. When my mate set it up for me he advanced it to 101.5* ATDC instead of the recommended 105* so that its more "torquey". I'm not sure how much difference it makes that you have a 998, but i know that I can definitely recommend it for 1275's. From what i've read around here though, you'd probably be just as happy with the RE-13
Also the wade cam seemed to be well made too - the measured figures exactly matched the quoted figures.
Geoff
EDIT: also to give you some idea of how the cam performs - with my slippery bridgestone tyres spinning the whole way through first gear i timed 0-100kmh in 9.9 secs - obviously theres more to it than just the cam but it does go very well...
