It is currently Fri Jul 18, 2025 5:57 pm
 Post subject: Morris 1300 engine
PostPosted: Wed Jul 27, 2005 4:18 pm
I THINK I have scored a 73 Morris 1300......I've been told this should fit into my mini 1000 (82 round nose)....the motor that is :lol:
I can't seem to find much info about this motor.....anyone know anything?? I think I've worked out it's an AD016 body etc. much like this:
KiwiMR2
1996 Libero GT
1979 Mini Cooper 1.3i
PostPosted: Wed Jul 27, 2005 4:58 pm
Did you google at all? First link:
http://www.motorbase.com/vehicle/by-id/1089/
Yes, A-Series 1275 'Detuned Mini Cooper engine' (website fact)
Probably just need to change the engine mounts.
PostPosted: Wed Jul 27, 2005 5:12 pm
Here in Oz the Morris 1300 was an auto. If you want to convert to a manuel there are procedures in the Mini Mod zone.
PostPosted: Wed Jul 27, 2005 5:25 pm
I swear I googled....for like 20 mins and read lots of bits and peices but didn't get any detail about the motor :(
This one is a manual :D
I JUST picked it up and drove it home, rego & warrant JUST expired last month & he didn't bother getting one as some vandals smashed the rear tail lights and kicked in the boot area etc. There were NO idicators so I got the missus to follw me home (5 min drive) ONE min into the return trip I get pulled up :cry: Was really looking at roughly $600-$1000 in fines for a $125 purchase price........LUCKLY I managed to talk out of it despite him saying pretty quickly I am to park it off the road, trailor it, and head home with a bunch of tickets. Explained that I had JUST picked it up and was de-registering it tomorrow & only taking it home for the motor & he let me off!! :P
BLODDY lucky. Seemed to pull ok, bit sputtery but has like NO fuel left in it.
KiwiMR2
1996 Libero GT
 Post subject: Re: Morris 1300 engine
PostPosted: Wed Jul 27, 2005 6:16 pm
KiwiMR2
That looks suspiciously like an MG1100....there is a picture of the one I drove to Wheels 2004 or 5 in Canberra...check the Events folder.
If so, it might be a good idea to leave it as it is....close ratio gearbox, twin SUs and 1275...also known as an Austin America???....anyway, well worth preserving for what it is mate :!: :D
PostPosted: Wed Jul 27, 2005 7:20 pm
Looking at it now I have it and seeing that pic it's not quite the same. Is as far as I can tell identical to this:
Im told the unit is and older pre A+ engine, and will have remote change, so I'll have to change the gearbox to make it fit my shell.....sound right??
KiwiMR2
1996 Libero GT
PostPosted: Wed Jul 27, 2005 7:24 pm
Here in Oz they called it an 1100S even though it was a 1275. Just to confuse everybody and trade on the S name.... Elsewhere in the world it was called a 1300, or Austin America (which was a 2 door ADO16 body).
They finally called the auto a Morris 1300 here, to distinguish it from the Morris 1500 OHC POS. :lol:
Last edited by drmini in aust on Wed Jul 27, 2005 7:25 pm, edited 1 time in total.
It's the equiv to our 1100 S I would say. Search for Morris 1100, you'll get plenty of info. Engine is the same as the Mini's, but brakes can't be used without modification.
PostPosted: Wed Jul 27, 2005 7:30 pm
Are they right about the gearbox??
So for $125 it sounds like a good buy, even just for the motor??
KiwiMR2
1996 Libero GT
PostPosted: Wed Jul 27, 2005 7:35 pm
Gearbox will fit, but remote mounting has a rubber sandwich plate in between to make the shift feel crappy and imprecise.
MiniMania site sells a solid sandwich mount, which rectifies this.
You will need to fit a Mini engine mount & bracket to the radiator end of gearbox, and fling the old 1300 mounts.
Also fit a `Mini remote shift' rubber mount to the end of extension housing.
Diff ratio will be a bit low, I'd bung a 3.44 in there while it's out. 8)
PostPosted: Wed Jul 27, 2005 7:43 pm
It is a Mk2 car not like the Mk1s that we had in aus.
Being a late car it could have a rod change gearbox, does it have a puddle of oil under the rear of the gearbox? :lol:
If it has a rod change you should be able to keep the gearbox.
PostPosted: Wed Jul 27, 2005 7:47 pm
Hmmm.....some of that goes right over my head :lol:
To be honest the gear changes in that were MUCH nicer than my current mini, which is sad as I spent like $1300 on that gearbox :evil: sometimes hard to get in the gears etc. The morris just changed and sloted in no problem.
$89.95 US dollars isn't to bad aye. The Mini engine mount & bracket etc...can't I use the one in my mini now??
What will the different diff do to the actual feel driving the car??
KiwiMR2
1996 Libero GT
 Post subject: Low Diff...
PostPosted: Wed Jul 27, 2005 7:52 pm
KiwiMR2
Yes you can probably use your existing mounts...just can't use the ones off the 1300....
The diff is probably a stump puller mate....it will rev its little head off...they were meant to be a town car...an English Town!! :D
PostPosted: Wed Jul 27, 2005 7:55 pm
And they were geared for 12" wheels with HIGH profile rubber.. :wink:
 Post subject: 30 clicks
PostPosted: Wed Jul 27, 2005 8:02 pm
So low profile rubber would improve the acceleration :!:
Lots of towns in NZ go from 50 to 30 zones in the built up areas last time I drove there...so very English Town speeds anyway :!:
