It is currently Tue Jul 15, 2025 1:04 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Aug 03, 2004 12:41 pm
From memory my Performance Superlites (like on the avatar) cost $660 for a set new, with nuts. So yes, $165 a wheel sounds right! If you get 10" rims, tyres will for the most part be cheaper and easier to source, but I guess that limits your brake selection if you want those Honda brakes and no flares. I've got S discs and flares so it wasn't an issue for me.
From what I'm told, $100 a tyre is pretty cheap for 12" rims, a mate of mine was ringing round a while back and got quoted around $130 a tyre for good tyres (Yokies or Falken, can't remember).
They are Performance brand by the way. Mine have 'PERFORMANCE' stamped on the rim. It is the actual wheel type which is Superlite, not the brand. They're beginning to become very common, I've seen them in bigger sizes on Cortinas, even Peugeots.
It was my impression that the 10x5 Superlites only came in one offset.
Anto.
PostPosted: Tue Aug 03, 2004 12:49 pm
68Delux wrote:
errr what's a good compromise tyre then? :lol:
I called bob Jane, they are Superlites not "performance" brand...??
12x5 Superlites wheel only $185 each
10x5 Superlites wheel only $165 each
Tyres areound $100 each
:shock: :? :cry:
When I asked about offsets they said they can supply any offset you want... they said to check out the superlite website and quote them a model number
http://www.superlite-wheels.com/wheelpage.asp?cat=1
The white ones look great :wink:
the rims in the website arent the rims you can get in aus, performance superlites are made in adelade aus not UK ;)
lookin for another clubby
PostPosted: Tue Aug 03, 2004 1:28 pm
Ahhh... that's where the confusion is! it's an aussie brand! gotcha...
will check it out! Performance brand Superlites :lol:
Lillee - 1969 Morris Mini K
PostPosted: Wed Aug 04, 2004 11:25 am
tempre tyres also have a very good after sales service, i bought the rims and over tightened the wheel nuts and stripped the thread, :? i have since been sent 16 wheel nuts for free, i would whole heartedly recomend tempe to anyone as they have looked after me very well.
PostPosted: Wed Aug 04, 2004 6:00 pm
Be careful with those nuts- they are prone to strip. I've seen it on Josh's car. I don't think the nut material is so good.. and there's not much stud thread length in the nut either.
Nice wheels though! :lol:
I think I'd modify them for Contessa nuts and washers, if they were mine... :wink:
PostPosted: Wed Aug 04, 2004 6:16 pm
but u can do that crap kev ;) wat are contesta nuts like ?do they go inside the wheel rather than just on it ?
PostPosted: Wed Aug 04, 2004 6:33 pm
Contessa nuts are a sleeve nut- they go inside the wheel, which has a chromed steel tapered washer mounted in it for the nut to seat in.
If you run with Contessa wheel nuts loose and it chews up the washers, you can change them. In fact when you buy new nuts, the washers come with them.
OTOH, if you run the Performance wheel with the nuts loose, it will shag the wheel.. :cry:
<edit> I'll post a pic of the Contessa nut when I find it. :wink:
PostPosted: Wed Aug 04, 2004 8:09 pm
I'd better watch that! I gave up using the original Mini brace ages ago coz you couldn't get the nuts tight enough. I use a proper cross brace or breaker bar now (ever since that interesting occasion with my contessas where two wheel studs snapped off!)
PostPosted: Wed Aug 04, 2004 8:45 pm
here's a Contessa nut & washer. Bit different to the Performance ones.
PostPosted: Wed Aug 04, 2004 9:25 pm
Yeah the jellybean mags (alloys) have the same style as that. Except the rod part of it isnt quite as long. True that it does have the tapered washer thing tho 8)
PostPosted: Thu Aug 05, 2004 9:25 am
yeh i have some ( 4)of those nuts, i was thinkin of using them, but it means another $75-80 which i cant afford at the moment :( also an *UPDATE*on those wheels and no spacers, they will run without spacers, IF the weights in the centre of the wheel are rermoved and replaced with outer rim weights. the caliper clears the inside of the wheel except that weight :? so maybe you could fit a 5mm spacer ? its so damn close
PostPosted: Thu Aug 05, 2004 9:44 am
hrmmm that close huh? I have to see for myself... I am more worried about not being able to get myself a set of honda discs now... Kev and his mates have scooped up Sydney's supply of hondas :shock:
yeah Tempe Tyres are a fair dinkum mob, delt with them before for a mate's car.
PostPosted: Thu Aug 05, 2004 10:07 am
lol the rice brigade will keep the honda supply steady, smashing their fully sik hondas :P
PostPosted: Thu Aug 05, 2004 10:13 am
LOL i guess so... I just have to be quick and be ready with my toolbax on the side of the road after an accident :lol:
PostPosted: Thu Aug 05, 2004 10:17 am
lol u will have to fight the towies off the cars :P try and find a large wreckers ;) usually full of early civics ;) my local has none :( lucky i already have my gear ;)
