It is currently Sat Jul 19, 2025 9:48 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sat Sep 10, 2005 1:59 pm
Well, we've had a look at the head gasket I took off about a month ago and decided that the block must be warped - it's black between the pots on the side that was next to the block.
Answer - out with the engine and do a rebuild. Get the block skimmed then put it back together with new bits and pieces.
BUT - in the meantime, we're doing a bit of an experiment. Got hold of some stuff called Seal-Up manufactured by CarGo. $10 for a 250 ml bottle. Sort of liquid glass stuff that hardens and forms a seal where the trouble is.
Will let you know how it goes. (Still pissed off though :evil: )
Rod Image
PostPosted: Sat Sep 10, 2005 3:00 pm
Ohwell bad luck. It's not all bad though, I mean, you havn't wasted money on getting the head done, because you would of had to do that anyways! 8)
PostPosted: Sat Sep 10, 2005 5:14 pm
That's right mate - and I get to do an experiment too - plus I have a re-co'd head and my old cylinder head should be OK after all
Rod Image
