you could always pick this up if it hasn't sold
Metro Turbo power unit brand new. Unique opportunity to acquire everything you need to build a complete new turbo power unit with factory reliability. All parts are genuine Rover or top quality parts supplied by MED in England. All machining work carried out by MED.
Block is rebored, faced, cleaned, new cam bearings. New welch plugs, gallery plugs, crank shells and thrust washers. New Omega pistons fitted to con rods. New Kent camshaft with new followers. New duplex timing chain, gears, tensioner. New turbo oil pump. New Cooper S type crank pulley and damper. New water pump & pulley. New genuine turbo electronic distributor and coil. New pre-engaged starter motor. Near new alternator.
New genuine turbo head casting with new valve guides and factory unleaded valve seats. Genuine turbo valves (sodium filled exhaust). New valve springs to match camshaft. New high lift roller tip rocker assembly, Rover alloy rocker cover with chrome nuts and new oil filler cap. Turbo fully rebuilt with new bearings and compressor wheel. New exhaust manifold, dump pipe and wastegate actuator. New turbo carburettor & inlet manifold & plenum chamber. New fuel pressure regulator. Factory ECU to control boost pressure. Near new genuine turbo flywheel and clutch assembly (lightened and balanced). New clutch plate, housing cover, release lever and bearing.
All gaskets, nuts, bolts, studs etc, crank case breather valves and hoses included. Complete new genuine ERA Mini Turbo exhaust system.
Also includes complete assembled gearbox (recently rebuilt) and brand new diff. Also transfer gear housing and gears. Asking $5000 firm. Located near Brisbane but will ship anywhere at buyer's expense. Call Julian on 07 3201 1709 or email jjg at gil dot com dot au.
