It is currently Thu Jul 10, 2025 5:15 pm
Post new topic Reply to topic  [ 377 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19, 20, 21 ... 26  Next
PostPosted: Sun Sep 11, 2005 8:45 am
coops wrote:
i just couldnt get my head around how the mini clamp went
Oh, welllll how about these then?
marcel@starchak.ca
starchak.ca
tdcperformance.ca
PostPosted: Sun Sep 11, 2005 9:33 am
Hey Marcel, I have a few D4R83 (16* advance) auto dizzys I want to modify to D4R85 manual spec (12* advance).
How hard is it to strip them weld up the advance stop? I've done Lucas ones before but not these. :wink:
PostPosted: Sun Sep 11, 2005 10:28 am
Piece O cake. It's just a slot that needs to be filled in. But unless you have a distributor machine to check what you're doing it's going to be a long week of messing around.
marcel@starchak.ca
starchak.ca
tdcperformance.ca
PostPosted: Sun Sep 11, 2005 12:10 pm
Thanks Marcel,
I've got a rotary table on the mill..... :P :wink:
PostPosted: Sun Sep 11, 2005 6:35 pm
thanks marcel 8)
Kev i have a d4r85 which i think will be too big for my sisters stock 998 :wink:
67' Matic
73' S
PostPosted: Sun Sep 11, 2005 6:53 pm
coops wrote:
thanks marcel 8)
Nah it'll be OK. Bobtel just put one on his 1098 & it's better than the 83.
 Post subject: Pulsar dizzy
PostPosted: Tue Sep 13, 2005 1:40 pm
Kevin, how are you guys going sourcing these things these days? What kinda money do they go for? The couple of times I've looked over here I've found nothing good. The couple I DID find had the right numbers but an entirely different casing/shape.
PostPosted: Tue Sep 13, 2005 4:31 pm
I don't pay anymore than $30. I can go to the wreckers and pick up about three dizzys at anytime.
PostPosted: Tue Sep 13, 2005 7:49 pm
Yeah I got the last one (D4R83) at pick 'n payless for $30, with cap & rotor but no coil.
I'm about to modify it to reduce centrifugal advance from 16* to 12* (same as an 85). Then I'll do likewise to Barney's one in the 1293A+.
I find 16* (32 crank*) is a bit much for a 1275- at 32* max advance point you finish up with hardly any advance down low, which makes it a slug under 2000.
PostPosted: Tue Sep 13, 2005 10:32 pm
Can you please let me know what wreckers this is from as i'm after a couple more and I paid $75 for the last one without leads or coil :cry:
67' Matic
73' S
PostPosted: Tue Sep 13, 2005 10:45 pm
coops wrote:
[I paid $75 for the last one without leads or coil :cry:
Teee heee heee, they're still $15 here in CanaDUH! :lol:
marcel@starchak.ca
starchak.ca
tdcperformance.ca
PostPosted: Tue Sep 13, 2005 10:48 pm
Yep Coops got ripped..
Yours is cheap,
Its airfare to here might blow the cost out a bit though. :lol:
PostPosted: Wed Sep 14, 2005 2:15 am
The D4R83's are 85 bucks here in Adelaide... with no coil or leads..... IF you can find one. :roll:
PostPosted: Wed Sep 14, 2005 6:32 am
I got myself a d4r85 the other day from the wreckers - it was 85 for one without coil but 140 for two with apexy filled coils (GT40T). So now I have two sets. One is in my car but if anyone wants the other d4r85 (manual) dizzy and coil for the $70 all up that they cost me - pm me.
PostPosted: Wed Sep 14, 2005 6:52 am
Mike,
Correct Bosch coil for these Pulsar electronic dizzys is a GT40R (1.5 ohm) but it's run without a ballast resistor..
Your GT40T coil is a 3 ohm, suitable for stock Lucas or Pertronix ignitor.
8)
