It is currently Sun Jul 06, 2025 12:24 am
 Post subject: 92's 4efte update
PostPosted: Fri Sep 02, 2005 12:04 pm
Finally got to do the braking tests and lane change manovering test
Yesterday took my car to A.I.R. and completed tests without a problem after waiting
the last few of months for the engineer to get enough cars together to make it all
worth while ie so I wasn't the only one having to hire the track
Only have to wait for his report then can get the car inspected and hopfully it will be all legal
4efte powered Clubman
supercharged 998 race car
PostPosted: Fri Sep 02, 2005 1:16 pm
Well done 92. I've got to do the same thing in a little while. Was it particularly difficult. Like, were you ever worried about not passing the tests. My engineer has access to the old dragway up here in Canberra so not much of a wait thankfully. Which track did you go to...
PostPosted: Fri Sep 02, 2005 4:14 pm
We don't have to do that up here in syd do we?
I aint herd of anyone doing up here unless you build a complete kit car...
Baracade
PostPosted: Fri Sep 02, 2005 4:23 pm
Dean depending on who you talk to there may well be this possibility. While not a complete kit car you have fundamentally changed your front subframe, and you are putting in a completely different engine. Not saying definitely but I wouldn't be surprised if you have to...But you are in NSW which seems heaps easier than ACT, QLD and possibly VIC...
PostPosted: Fri Sep 02, 2005 5:16 pm
AFAIK over here in WA a stability test is only required when the steering geometry has changed. This includes fitting oversized rims/tyres.
Hoping to get away without it as I am using std subie suspension/track/rims
and I haven't budgeted for it :roll:
PostPosted: Fri Sep 02, 2005 5:41 pm
dean dont worrie mate, we have no such test here. The only time the engineer even saw mine moving was when i drove it down the street to get on the weigh bridge :D
1974 Moke - 998cc
PostPosted: Fri Sep 02, 2005 6:34 pm
Buggers... :)
PostPosted: Sat Sep 03, 2005 10:08 am
Wasn't particularly hard the braking test involves doing 15x 60kmh to 0 stops each within 25 secs. followed by 2 100kmh to 0 stops which must be made with a minimun of .8g
The lane change test the car is traveling at 110kmh the drives through a simulated lane with cones and has to change from one lane to another then back again without hitting any cones, the width of the lane is determined by car width so it is even for any car big or small
In SA we don't have capacity to weight restictions but have things like the engine cannot produce more than 15% more power than standard doesn't count for conversions though I think but I cannot increase the power of the starlet engine legallyby more than 15%
PostPosted: Mon Sep 12, 2005 12:40 pm
thats more for emmissions than safety.. emmissions tests are expensive and a hassle
Expert in training
PostPosted: Mon Sep 12, 2005 12:56 pm
all the rules should be the same across all states..havnt checked out the sitch in melb yet but i know there are mini hybrids around
sounds like a fun test though
PostPosted: Fri Sep 23, 2005 12:58 pm
Location: thornleigh sydney...round crnr from suzitech!!!!
engineers certificates are only valid in the state that they are issued in!.
blake :wink:
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE :) yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
PostPosted: Sun Sep 25, 2005 10:54 am
Yeah but once registered the car is legal in every state...
PostPosted: Sun Sep 25, 2005 11:48 am
Well Done 92
Blackrz
(998cc Clubman)
- = :Zone 3 Goober: = -
http://photobucket.com/albums/y142/blackrz/?sc=1
"I Live My Life A Quater Mile At A Time"
PostPosted: Mon Sep 26, 2005 8:15 pm
but once you try to register the car in another state u will require another engineers cert,
blake :wink:
ausmini member 195
PostPosted: Tue Sep 27, 2005 12:29 am
That's an interesting one lobby, my engineer is a registered signatory in both ACT and NSW I might ask him about this. I would have thought that once passed for rego you wouldn't have to get new cert just to register in another state. Still given that ACT has some of the harshest engineering and rego laws I think moving to another state will make things easier (like NSW!).
