It is currently Mon Jul 21, 2025 2:14 am
PostPosted: Thu Oct 13, 2005 3:55 pm
The Morris 1100 auto is a rare car. Fix it up!
True. :lol:
If you want an 1100 crank to make a stroker 998 (to 1098) just ask here. I'm sure there are still a few about... :wink:
ps. you would need 1100 pistons too.
I have 2 x 1098 cranks here and they were going to become land fill but yours if you want(you will have to organise the freight though). They came out of running 1098cc motors but dont want anything for them - will even throw in the rods as well.
Let me know if you want them but will have to go through the usual checks though...
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Thu Oct 13, 2005 4:00 pm
heya...
just did the calculations.. the 1098 is an 1153...
going by, 6.5 cm wide....8.5 cm deep
do i have any bores left before its dangerous??
1978 Leyland clubman S.
PostPosted: Thu Oct 13, 2005 4:02 pm
fuzzy-hair-man wrote:
K-Bar wrote:
seems im likely to just go and rebore the 998..throw in some 1100 pistons and crank.
Move over the head too....
K-Bar wrote:
any sugestions in pistons and size?? taking in mine flat top.
The size will be dependant on how big you do an overbore which will depend on how many overbores have been done before and how badly worn the bores are, you can't know this until you have the block out and take it too you machining guy. Then you start looking for pistons.
I don't know much about what are good pistons etc and wether 1100 pistons come with flat tops or not, if they don't you can raise the CR by shaving the block :wink:
Pistons are many - I like the Hypatec ones as they are a bees dick lighter than std. A slight dish is ok -but really depends on what you want out of it. The lip wont overly be a concern but I would get the machine shop to look at it. I think the 20 oversize would be more than enough - the Hypatecs' come in a 30 oversize too. Good towing motor and ideal for loping slopes - plenty of poke.
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Thu Oct 13, 2005 4:06 pm
kool
so.........what overbore is an 1153??
sorry..im new to all this...loving it
PostPosted: Thu Oct 13, 2005 4:10 pm
K-Bar wrote:
heya...
Please, talk mm... :lol:
Actual stroke of 1098 is 83.7mm, not 85.0.
Bore is 64.6mm stock, so it's probably only at +.020" now. You can still get +.020", +.040", +.060" stock sizes- and as Rob said Hypatec do a +.030".
Also, GR still has some nice flat top +.080" ones I think. :P
<edit>
Back in the `good old days' we used to offset bore them to 68.0mm and use Hepolite or Repco `Imp' pistons, but these are rocking horse dung now. Although I think JP Pistons still make them.
It gave ~1220cc.
Hardly worth the bother these days- just bore a 1275..... :wink:
PostPosted: Thu Oct 13, 2005 4:33 pm
haha, yeah, i was using a tradies measuring tape..
wats a good price for doing one bore up?? (30)
think most of my questions have been answered, thanks to ausmini.com :D
PostPosted: Thu Oct 13, 2005 5:02 pm
Standard rebore & hone job- probably $100-150, + the pistons. Rings come with them... :wink:
