It is currently Mon Jul 21, 2025 2:40 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Tue Oct 25, 2005 6:23 am
A heat gun and Scraper works really well on the inside gaurds& fire wall then a Wire brush on a drill or grinder. I did the whole rear and front end using this method :wink:
PostPosted: Tue Oct 25, 2005 8:17 am
yeah...might have to go with something more hardcore though...coz the underside of my car is encrusted with dirt...maybe it was mud at some stage...but there's a fair bit under there...especially under the wheel guards...which makes sense :)
Bling me up Scotty!
PostPosted: Tue Oct 25, 2005 10:11 am
Maybe a really good high pressure washer? Not one of the hooby things, a fair dinkum one like they use to clean up bricks etc. Just don't bend any panels though that is most probably unlikely as the inner gaurds etc have plenty of shape.
Chris
Everything I like is either
PostPosted: Tue Oct 25, 2005 10:17 am
you'll be surprised how much is under thier..and the scraper makes it a lot easier :wink: but do make sure you a mask and glass's
PostPosted: Tue Oct 25, 2005 11:05 am
awdmoke wrote:
Disabled, make sure you wear a good dust mask & have proper ventilation.
There was a reason they outlawed the use of sand for blasting - silicates in the lungs causes all sorts of terminal lung diseases :!:
so sand is bad? i have a mask suitable for spraying (paint) would this be good for blasting aswell? would i be better buying that garnett sand stuff or something?
I have a problem.. apparently
PostPosted: Tue Oct 25, 2005 11:16 am
garnet is pretty cheap & well worth it over the amount of dust you get with sand
but if you must, that respirator for painting should do the trick
PostPosted: Tue Oct 25, 2005 11:29 am
guess all this depends on what the 3 panel beaters i have lined up tell me this week :P if they can do it for ~$5000 then i'll not bother DIY'ing the body and paint work...if not then i guess i'll have to look into it...
Bling me up Scotty!
PostPosted: Tue Oct 25, 2005 8:06 pm
I used a 4" angle grinder with straight (not cup) twistknot brush under the 850. Man, does it take that crap off, but you come out from under looking like a `coloured person'... (no offence intended) :wink:
PostPosted: Tue Oct 25, 2005 10:37 pm
yeah i can imagine...it looks like it'd take an angle grinder to get off :P
Bling me up Scotty!
PostPosted: Wed Oct 26, 2005 6:48 am
Doc its a "coloured fella" (no offence intended). :)
PostPosted: Wed Oct 26, 2005 10:46 am
well i went out and bougt a 25kg bag of garnett, cost me $38 im sure ive seen it cheaper elsewhere, but i was too lazy to shop around.....and went home to try it out, works pretty well on the subframes if you are patient and have a big enough compressor, mine could keep the preessure up but it was running practically the whole time as it says to sand blast at 6 bar in the instructions, and i beleive thats actually bad for the compressor? anyway, ill upload some pics later...
PostPosted: Wed Oct 26, 2005 10:54 am
I get mine for a bottle of Beam per 1tonne bag :wink: :D
PostPosted: Wed Oct 26, 2005 11:05 am
hahaha so you pay less than me and get alot more!! :( i think i might just pay someone, turns out i got a mate who is "connected" with a sandblaster, also got 2 mates connected with painters and one of them can get paint at either cost price or trade price, and another mate who works at a place that does truck stuff?? and they have a gieant spray booth there that costs a case of beer to use on sundays :D so i feel like im set lol
PostPosted: Wed Oct 26, 2005 9:24 pm
I had my cooper S PLASTIC bead blasted when it was done in '96.
I'm surprised cos I thought that option would have come up by now.
The plastic beads rip the paint off, but can't touch the steel. It simply polishes it instead.
I can still find beads even now if I go looking, the box section above the pedals is a good area to look.
Make sure you remove as much of the sound deadening as you can, this stuff doesn't come off very easily with the beads.[/b]
