It is currently Sun Aug 03, 2025 5:03 am
Post new topic Reply to topic  [ 93 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
PostPosted: Mon Sep 12, 2005 8:29 pm
I'd give Graham a ring. 8)
PostPosted: Tue Sep 13, 2005 7:24 am
Boostedmini wrote:
thanks guys,
i really do not care what it is like to drive cause when i do drive it its allways above 5k and on 15psi
Whichever way you look at it, you just gotta like that!!! :D :D
Way to go Grant, no wonder it broke thou!
Steve
PostPosted: Tue Sep 13, 2005 2:34 pm
thought you would like it Steve,
ok here are some other cams of choice
1 Duration Lift
In 264 360
ex 280 400
2
in 276 385
ex 300 400
3
in 264 351
ex 292 389
im thinking number 2
100% Pure A Series Turbo
PostPosted: Tue Sep 13, 2005 7:38 pm
I reckon #2 has too much ex duration for a turbo... :wink:
PostPosted: Tue Sep 13, 2005 7:54 pm
I just had a Re13 for a turbo cut today so he still has them and knows them off the top of his head.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Tue Oct 04, 2005 11:45 am
ok i have a few small udates.
I finally pulled the engine out on sunday and split the box from the engine to find that the lay gear kit has two teeth issing from second gear, have not gone any further yet as i dont have the money and all that much time right now, but i will be fitting the MK1 "S" box i have and build one good box out of two using this damaged box and another case i have.
and now some of the damage to the engine side of things
PostPosted: Fri Oct 28, 2005 2:26 pm
Ok some more updates,
Yesterday i have order from Avonbar, their Phase 3 turbo cam kit which has 400" lift plus my 1.5 rockers should be interesting it comes with valve springs, cam followers, plus their ARP head stud kit with flanged nuts, ARP rod bolts, ARP main bearing stud kit.
I have ordered from MED engineering their Omega forged +20 pistons and rings, en24T flywheel bolt and lock washer, en24T crank pulley bolt.
from altered image coach works (Paul Vickers who builds miglia motors) i have ordered their Steel main bearing cap kit which has a centre 4 bolt main cap, and steel end caps.
all this should be in my hands in two weeks if not less.
from karcraft i have all other items including bearings, thrusts, gaskets turbo oil pump etc.
I have also ordered soem stainless braided brake lines and have mounted my brake booster under the drivers side guard wiith a stone shield around it.
i am hoping to have it back on the road by mid november to late november.
PostPosted: Fri Oct 28, 2005 2:32 pm
nice pics, good luck with it
PostPosted: Thu Nov 03, 2005 9:19 am
ok here are some pics of the items that have arrived from UK
still waiting on a few other items too
PostPosted: Thu Nov 03, 2005 9:49 am
nice shopping items there Grant! 8)
PostPosted: Thu Nov 03, 2005 11:04 am
:lol: I love getting new toys..
hurry up and make it work again. :P
PostPosted: Thu Nov 03, 2005 1:22 pm
wow grant you are going all out on the rebuild :D Cant wait to see it back in a running 100%, get it done for the 17th wakefield day 8)
Are you going to get it dyno tuned this time? using the same turbo setup?
1974 Moke - 998cc
PostPosted: Thu Nov 03, 2005 1:31 pm
yeah should be a good one, but no can do on the 17th its my brother wedding.
as for dyno, absolutley straight to castle hill, thsi turbo setup will remain till the 8 port is done.
wel i just got back from GR's and bumped into the good doc there too, we all had a good chat and GR is checking over my head and looking at my guides and valves etc, he has given me a tool so i can now measure my piston height in the block to work out my comp ratio and work out how much a have to remove of the pistons to achieve the desired comp ratio of 7.5:1.
we also spoke about cams and a few other ideas from GR too.
should be able to take pistons to him on monday and then have them all back and fitted to the rods by the week after that.
ok update, finally all my bits from avonbar inc cam kit have arrived, i have also had to go back to a std stroke crank to try and get my comp ratio to a better level, i am aiming at 7.5:1, so the capacity now is a 1293cc, as the motor is currently at 8.8:1 i need to find another 6cc of total chamber volume, GR is going to do a little more head cutting plus a small amount of maching in the pistons to find that extra combustion chamber volume, so the dummy build has started and all is good, so i will go to GR on monday and give him some bits and then a weel later will start the final build up.
been too long having withdrawals :oops: :oops:
PostPosted: Mon Dec 05, 2005 9:53 am
ok so GR is moding my head a littl emore to get a few more cc's in the chambers 2 maybe 3 if he can and then another 2 in the pistons will be enough.
here is a pic of my head as it was prior and when i get it back i will put some up of the GR mods.
i just recieved soem more parts from minispares, new harmonic balencer, centre oil pick up, soem idle gear thrusts and output flange collets too.
getting closer
PostPosted: Mon Dec 05, 2005 12:32 pm
nice photos, that was some serious wear on your old parts
Users browsing this forum: No registered users and 70 guests
